Question about Pool & Spa
Timberwolf arctic spa pump (new) won't power up. Relay clicks and display shows 53 and flashes "off"
  • 120 Answers
SOURCE: 1991 tracker I put in a new fuel pump relay. the
probably becuase its faulty...try replacing it and go from there...or else there is another source of resistance in the circuit some where....also, check your fuses....a blown fuse will stop flow of current as well.
Posted on Nov 14, 2009
Coastsider
  • 331 Answers
SOURCE: Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Posted on Apr 14, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
  • 111 Answers
SOURCE: New pump overheats
ICE is potential freeze condition warning. Should not relate to the pump issue.
Is your new motor same Amperage as old one?
Is the wet end(pump) on the new pump the same horse power as the one it replaced?
Lack of ventilation for the motor, or clogged motor vents.
Check for undersized wiring or poor electrical connections.
Check if your pump has a thermal overload, this safety mechanism will turn the motor off when it gets too hot. The pump should restart once it cools down.
Remove the intake plumbing and visually inspect the impeller, observe for impeller failure. Spin the impeller to see if it turns without impedance.
Before you inspect the pump turn of the power to avoid electrical shock!
Posted on Feb 20, 2012
SOURCE: laz y spa pump showing e02
our lay-z-spa was showing the e02 and not working so we checked on here and found some great ideas and went off to try them. as we was putting the pump unit back together we noticed that pipe B was flat !!!! so we rounded the pipe and slightly raised the pump unit and turned it all back on and it is now working fine so we thought we would metion it on here x
Posted on Sep 15, 2012
High speed pump won,t shut down. New pump installed and new sensors
check for stuck high speed relay..if its stuck there has to be a reason..unplug the tub and check relay for fused contacts on the relay..clean with sandpaper or a fingernail board..(emery board)
Nov 08, 2013 | Pool & Spa
2001 arctic spa is showing error code FLO
FLO is for not enough water flow
This is a filter issue or pump issue. Remove filters and see if it goes away. If it does get some new filters here: http://www.hottubworks.com/
If it does not go away call us and we will walk you through trouble shooting. Most likely a circ pump if not filters.
Oct 14, 2012 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
Pump won't run
that is showing the relay is getting the signal from the aqualink check voltage at that relay if voltage to the load of the relay check voltage to pump if voltage bad motor if no voltage bad relay or line to motor
Jul 17, 2012 | Jandy Pool & Spa
Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
Nov 16, 2011 | Hydro Quip Inc Pool & Spa
Pool & Spa Logo
43 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
