Question about Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas Tank & Cap
How do i check spark on my echo leaf blower
I have replace the spark plug, fuel filter and cleaned the fins and cannot get it to start.
  • 1,057 Answers
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
Posted on Oct 22, 2016
4 Suggested Answers
SOURCE: Need to replace fuel filter
Fuel filter is located inside the fuel tank. You have to make a hook out of about 10" of stiff wire (wire coat hanger works perfect) Hook end should be about 1/2" wide. Remove the fuel cap, insert the wire hook and snag the fuel supply tube with the filter attached to the end. Pull it back through the fuel filler opening, replace the filter and reinsert.
Posted on Apr 15, 2009
bbreton
  • 437 Answers
SOURCE: cant get fuel into cylinder will not fire
Carburetor may need rebuild, sound like diaphragm are not pumping fuel.
I would get a compression test on the cylinder to see if it is at 100 psi. This is the compression the cylinder needs to be at to run. You may pay a few dollars to get a shop to do this but it will tell you if it is worth fixing before you spend alot of money.
Posted on Sep 30, 2009
  • 51 Answers
SOURCE: Echo leaf blower will not start....leaks fuel from
sounds like u have a carb problem,ether theres debris stuck in needle valve needle is stuck open or the check valve diaphram is bad.take carb off on one side there is a plate with 4 screws remove then agasket and diaphram remove them some times they stick to carb so use a razor blade to go underneth diaphram all around from center youll see a metal see saw with a pin going through if u push on center it will lift needle valve on other side make sure it goes all the way down or remove by removing screw that holds pin in and blow out with air lightly may blow seat out after that on other side of carb take other plate off by center screw that diaphram has 2 little flaps check valves make sure they are limber and not wrinkled or bent if so u can get new ones at good mower shop or parts supply hope this helps
Posted on Aug 08, 2010
Echo ES210 Blower will not start
Since you are getting spark from the plug it sounds like a fuel problem. I would check all the fuel lines and make sure they aren't plugged and ensure the filters are clear.
Jun 27, 2016 | Echo Garden
Echo PB-251. Wont run full speed,changed ,plug,filters
I'm 99.9% sure it's the fuel line. The ethnoll in gas really shrinks the oem fuel lines
Jan 13, 2015 | Echo Pb-251 Leaf Blowers
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
Motor not accelerate past idle, bogs down...
yes,check your spark arrestor screen in the muffler
Apr 22, 2009 | ECHO, Inc. Shred n Vac
Echo PB1000 leaf blower will not start
Check fuel lines and fuel filter. If unit has been sitting all winter carburetor may need to be overhauled.
Mar 29, 2009 | Garden
Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas Tank & Cap Logo
94 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
