Question about Kitchen Appliances - Others
Regal 505 replacement blades?
I need replacement blade for Regal 505 coffee and spice grinder. Where can I find one?
  • 4 Answers
SOURCE: blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Posted on Jan 12, 2008
SOURCE: Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Posted on Jun 26, 2008
abhishek33
  • 1239 Answers
hi sir  thats only to remove older blade[damaged] apply lubricant to loose it and leaving for some time try to shaft with screw drewer
Posted on Sep 10, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Posted on Mar 08, 2009
KMusselmann
  • 247 Answers
SOURCE: need a kneading blade for Regal Kitchen Pro automatic breadmaker
here is a site that sells them. Hope it helps. Pls rate the answer
Kurt
http://breadmakerguru.com/
Posted on Mar 30, 2009
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
How do I clean the Black 3-oz. Coffee Grinder by Krups? Remnants of all the spices I used are stuck in the blade.
The best idea is to grind some rice to remove the spice pieces that are stuck. After doing this, wipe it clean with a paper towel or a cloth towel. Try not to get it wet, this makes all the spices get clumpy and it will be even harder to clean.
Jan 24, 2013 | Kitchen Appliances - Others
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Need kneading blade for old Regal auto breadmaker K6773
Nope, haven't solved the problem yet. I got into the wrong category of breadmaker: mine is a regal K6773 "Automatic Breadmaker."
Dec 16, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Blade replacemen braun grinder
Dec 16, 2007 | Braun KSM 2 Electric Blades Grinder
Kitchen Appliances - Others Logo
383 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
