Question about Westinghouse W32701 27 in. LCD HDTV
Lights up blue then goes dark - Westinghouse W32701 27 in. LCD HDTV
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Tv powers up to green,but just lights up dark blue screen,nopicture,sound,etc.
I just answered that a while ago, why do you people ask the same thing several times?
Sep 30, 2012 | Dynex DX-LCD32-09 LCD TV
Where is the cooling fan relay located on a 94 Chevy Beretta 3.1?
It is located at the rear of the engine compartment behind the right strut tower. Thyere are 3 or 4 relays there in a cluster. The one you want has 4 wires: 2- RED 1- LIGHT BLUE and 1- DARK GREEN.
Both of the RED wires are HOT at all times. They come from fusible link [G] located at the starter solenoid (RUST colored).
The LIGHT BLUE wire goes to the cooling fan. This one should be hot whenever the Powertrain Control Module (PCM) turns the relay on. One of the RED wires provides battery positive voltage to the LIGHT BLUE wire when the PCM grounds the relay primary (coil) circuit to operate the relay.
The DARK GREEN wire is the relay control circuit from the PCM. One of the RED wires feeds battery positive voltage to the relay coil and the PCM controls the relay by providing GROUND for the relay coil. The DARK GREEN wire goes to Connector #2, PIN #2 at the PCM.
May 12, 2012 | 1994 Chevrolet Beretta
Radio was removed from my 91 Seville and replaced with aftermarket CD player radio. I would like to use this radio in my shop. I have 12 DC supply and speakers and antenna. Note: There is no place to plug...
This should be the wire combination for your car: nstant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Speakers
Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Speakers continued
Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Apr 13, 2011 | Car Audio & Video
I,m putting in a new sterio and I need to know the location of the colored wires on the radio harness. Where each color goes to
Here you go. I hope this helps you and good luck...
1994-97 Chevrolet Corsica Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Front Front Speakers 4" x 6" Kick Panels Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Mar 26, 2011 | 1994 Chevrolet Corsica
What color is positive speaker wire on 1998 blazer
1998 Chevrolet Blazer S-Series Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Rear Doors Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Mar 17, 2009 | 1998 Chevrolet Blazer
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Westinghouse W32701 27 in. LCD HDTV Logo
21 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
