Question about Epson Stylus Pro 4800 Color Photo Printer (C593001UCM)
Communication error occurred. Check the I/F cable connection and power of printer. for 1390 printer in adjprog.exe
jackboy
  • 2985 Answers
SOURCE: A communication error has occurred.
A.Unplug and re connect the printer B.Go to Printers and Faxes and click on install printer. When sked for CD or go to list- select - Go to List Select Make Select Model Click OK Make it your default printer
Posted on Jun 30, 2007
checkitright
  • 1362 Answers
SOURCE: communication problem
Are you saying that you have a parallel to a USB input !!!!!
Never seen or heard of one, that may be your problem USB goe to a USB input, Parrallel can go to a parrallel or to a network connection.
Posted on Oct 11, 2007
SOURCE: i cant run the adjprog.exe even if changed the date of my computer
1111111
Posted on Nov 08, 2008
sherlyn c
  • 134 Answers
SOURCE: communication error shows even though all cables etc are plugged in
Sorry for the inconvenience.
Please make sure that you can copy on standalone first to isolate the issue. To make a copy, place a document inside the scanner, then close the document cover. Load 10 to 20 sheets of regular paper into your printer. Press the copy button to start a copy mode. Then press the start button to begin copying.
You may also need to trash and reinstall the drivers.
To get the most recent driver compatible with your computer, please log on to epson.com. Please follow the link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=72303&prodoid=63059192&infoType=Downloads&platform=All
Then add the printer on the queue.
If you need further assistance on how to trash the printer sw properly on a mac os, please do not hesitate to let me know or post another issue here. Do not forget to include the full version of your mac os too. We will be more than happy to help you.
Thank you for choosing epson.
Sherlyn C.
Posted on May 05, 2009
cns assoc
  • 677 Answers
SOURCE: Parts inside your printer are at the end of their
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Posted on Apr 05, 2010
What is error 004 and what do I do about it
This error refers to the communication error between the printer and its connection. To help you troubleshoot the issue, please follow the steps mentioned below:
-Turn the printer off using the power switch located on the printer panel.
-Wait 10 seconds, turn the printer back on, and check if the error message still occurs.
-If the error persists, reseat all of the toner cartridges. For more information about reseating toner cartridges, refer to the user's guide for your printer manufacturer.
-While reseating, clean the toner cartridges with clean cloth and verify that the orange plastic covers have been removed from the developer rollers.
-Turn off the printer, and disconnect the AC power cable and communication cable (Ethernet or USB, depending on set-up).
-Remove the Imaging Drum and verify that the developer rotor frame is not bent. If the frame is bent, please contact printer manufacturer to replace it.
-With the Imaging Drum removed, Open the front cover and then push on the toner cartridge handle to determine if the carousel moves freely.
-Reconnect the AC power cable, turn on the printer, and check. If the error still occurs, please contact your printer manufacturer for further advice.
GuruAid.com
Mar 28, 2016 | Office Equipment & Supplies
Adjprog.exe
You can get Adjprog.exe from here
http://www.imprek.com.ar/reseteadores/tx125_t25_tx135.rar
Solucionado AdjProg exe para epson tx 135 alguien lo tiene Impresoras...
Sep 15, 2015 | Office Equipment & Supplies
Communication error ' error coad 20000010 for epson 1390 printer
Hi Shwe,
Go To Below official Epson Printer Page For Your problem,
Communication Error
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
May 15, 2014 | Epson Stylus NX300 All-In-One InkJet...
Error 2100012C
This article deals with the various Communication Error issues when attempting to reset an Epson waste counter using an AdjProg service utility, which I'm pretty sure you're trying to do:
http://www.octoink.co.uk/kb/questions/119/
Dec 17, 2013 | Epson Office Equipment & Supplies
Communication error 20000068
This error usually means the AdjProg utility you're trying to use is not compatible with your printer model.
There's some more information on the issue here:
http://support.printerpotty.com/2013/error-21000068
May 01, 2013 | Epson TM-T60 Printer
Epson stylus t30 error code 2100012c
This error is usually shown when using the AdjProg to try to reset the waste ink counter.
The error code is caused by one of the following:
1. More than one Epson printer is connected (turn any others off)
2. The utility can't connect using the "Auto" setting for the printer "port" (Select the specific printer port using the "Select" button).
This issue is covered with other AdjProg errors in this article
Jan 09, 2013 | Epson Stylus C84 InkJet Printer
System error e225
Hello 3G,
To resolve the issue Error e225,
Turn the main power switch off and then back on-ICMF 4000 series/D400 Series
or
Update the firmware :
There is a risk that the MF4150 will not operate if power interruption occurs
during the firmware update. Please make sure MF4150 is connected to
reliable AC power source.
1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
Computer Requirements for update
- Microsoft Windows 2000 or XP (32bit)
- Equipped with a USB port (either 1.1 or 2.0)
- Free disk space: 100 MB or more
2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
5. Make sure the USB cable is directly connected to the MF4150 and your computer.
  • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
  • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
  • You need to log on as an administrator to perform this update.
  • Make sure that no other applications are running on your computer.
6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
  • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
8. Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
9. Confirm that the machine is in the ready status, and then click [Transfer]
  • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
10. The firmware is transferred to the printer.
  • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
  • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
11. When [Firmware transfer is complete] appears, click [Exit].
The printer starts the update process automatically.
<ERASE FLASH ROM> appears on the printer's display while the existing firmware is being erased.
Then printer's display shows <FIRMWARE UPDATE> while updating the firmware.
When the firmware update is complete, the printer's display shows <FIRMWARE UPDATE OK> <MACHINE POWER OFF/ON>
12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
Jun 22, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Hi, I just installed a given Stylus C46 and the green (power) and red (ink) led light alternativly. I try to print something and nothing happen... What can I do ?
Dear friend,,
It's because of the EEPROM Error.Try the following program.
http://www.mediafire.com/?xydczelivyi
download it.Run ADJprog.exe.select printer model Epson c46,destination asia,Port usb or Something you've connected.Click ok.Select Cosumables maintanece counter click reset.
Hope it'll help
Mar 07, 2011 | Epson Stylus C46 InkJet Printer
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
139 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
