Question about Greenfield Industries Disston #752980 Mm 7/16" Chan Mandrel
How to replacing clutch plates on greenfield ride on mower
Have greenfield fast cut 34 mower replace drive belt but have problem going forward up hills clutch is worn half mm could clutch be glazed
Are you sure your new belt is the proper length A quarter inch too long could make it slip. Something to try is spray your belt with belt dressing and see if that helps That will help stop it from slipping.I had to do that with one of mine when my belt was not the right size. I shot spray about once a week one summer.
Dec 07, 2014 | Garden
How do I replace rear axle bearing greenfield ride on mower
some transaxles ARE NOT serviceable...
Sep 01, 2014 | Garden
GREENFIELD 8, 11 & 12 HP ANNIVSARY manual
Some manufacturers will not sell the full manual to consumers, perhaps yours will.
Your best bet is to email them with the full model and serial number of your mower with your request:
http://www.greenfield.com.au/contact.html
Jun 07, 2014 | Garden
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
replace chain -- if it streches length way on floor more than a one quarter of a inch --chain is wore and needs replacing
Have a Greenfield Evolution 2000 mower , the forward drive clutch is slipping badly on hills is ok on the flat, what is required to fix this problem. Can the clutch pads be replaced or are complete clutch...
The Greenfield clutch (drive belt) is adjusted by spring pressure pulling a long rod that has serations on it. Either the belt has run out of adjustment (= new belt needed) or the adjuster has stuck. Lift up the seat and push the adjusting rod that has a big spring attached to see if you can move it towards the front. Look at the pulley beside the rod, if the belt has stretched too far, the pulley will be hard up against its slot. The pulley moves towards the front to tighten the belt. I just push with my leg to get another "click" out of the adjusting rod. New belts are cheap too.
Oct 31, 2010 | Garden
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Jul 18, 2009 | Garden
Greenfield Industries Disston #752980 Mm 7/16" Chan Mandrel Logo
35 people viewed this question
Top Greenfield Industries Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Greenfield Industries Measuring Tool and Sensor Expert? Answer questions, earn points and help others
