Question about Hoover HTC243 Top Load Washer
Clean the lint filter on Hoover 550m - Hoover HTC243 Top Load Washer
2 Suggested Answers
beltronic205
  • 1474 Answers
SOURCE: Replacement part: lint filter located on main frame
If uk try espares.co.uk
Posted on Nov 20, 2009
HW5513M Hoover washer dryer has a coin filter which I clean regularly, but washer door seal (and hence laundry) has wet fluff buildup. How do I prevent this?
There should be a lint filter somewhere in the dryer. Even with a lint filter you are likely to get accumulation around the door seal.
Aug 14, 2016 | Hoover Washing Machines
Hoover hvc 180 not drying clothes
You will need to check the internal, as well as the external vent line for lint buildup.
Apr 28, 2012 | Hoover VHC391 T-80 Dryer
I have a Hoover 500mb, 5kg HD Top Loader washing machine. The problem I am having is the clothes always have lint and other stuff on them after being washed. I have tried taking the agitator off and seeing...
have you done a clean ,hoover have this built in you need to do every so often the filter could be clogged do a clean don't put anything in when your doing this ,how old is it
Jun 16, 2017 | Hoover Washing Machines
How do I fix a hoover 550m washing machine not is not pumping water to drain out and empty the wash bowl. Everything else works fine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 20, 2011 | Hoover HTC243 Top Load Washer
How to clean out the machine a top load 7.5 kg load hoover
Open the lid, locate the centre washing spindle/arm then undo the cap on top of the spindle (this will either unscrew or just slip out, Pull up.) inside there you will see the lint filter, wash this out and put back.
Nov 02, 2010 | Hoover HTC243 Top Load Washer
Hoover HTC243 Top Load Washer Logo
55 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
