Question about Hoover HTC243 Top Load Washer
Where is lint filter on Hoover 550m washing machine
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 188 Answers
SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Posted on Mar 01, 2009
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
Posted on Mar 15, 2009
louislevel_2
  • 374 Answers
SOURCE: Where is the filter on a Hoover softwave AC 270 washing machine
hi there,
here are top load washing machine parts are located.on figure 127dff9.jpgyou can locate where the filter was located,may be this will help you.,hope you can solve but if still not run,feel free to log in to fixya we are here to serve you better.have a nice day,rate my solution.thanks a lot.
Posted on May 19, 2009
  • 3 Answers
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Posted on Nov 05, 2009
HW5513M Hoover washer dryer has a coin filter which I clean regularly, but washer door seal (and hence laundry) has wet fluff buildup. How do I prevent this?
There should be a lint filter somewhere in the dryer. Even with a lint filter you are likely to get accumulation around the door seal.
Aug 14, 2016 | Hoover Washing Machines
Hoover 550m -wont spin
This Could Be A Problem With The Control Switch Or Door Switch.
Is It A Separate Spinner Or All in One
Apr 04, 2013 | Washing Machines
Is there a lint filter on a hoover electra 540 washing machine
Did you get a manual with machine? answer is in there. if not google your units name and model number with the word manual and it should come up
Mar 12, 2011 | Hoover Washing Machines
How do I fix a hoover 550m washing machine not is not pumping water to drain out and empty the wash bowl. Everything else works fine
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 20, 2011 | Hoover HTC243 Top Load Washer
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
Hoover Washing Machine 550M. Cycle incomplete, clothes still wet with soap powder.
this sounds like the motor bushes have worn,check them,they are easy to replace for about £10.00
Jul 14, 2009 | Kenmore 44102 Front Load Washer
Hoover HTC243 Top Load Washer Logo
177 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
