Question about Honeywell Heating & Cooling
Air comes on when honeywell thermostat is off
Had the air turned on, the it cooled off so we turned it off; however the air is still running. Why is this happening and what can I do to fix it?
ACTECH
  • 80 Answers
SOURCE: Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Posted on Dec 19, 2007
SOURCE: Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Posted on Oct 14, 2008
benmartinez
SOURCE: Heat pump that just blows cool air
I have a Honeywell heater i'll set my thermostat to 76 and ill turn on the heater and it would turn on... but when it get to 76 it turns off so when the temperature drops down and the heater clicks back on all i get is cold air .. it only works on the 1st time what to do ?
Posted on Dec 24, 2008
  • 588 Answers
SOURCE: how does one set a Honeywell ultrastat thermostat
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on May 11, 2010
SOURCE: my honeywell heater thermostat is only blowing
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Posted on Nov 27, 2010
I have a standard digital Honeywell thermostat. It it running the furnace in opposite modes.
not likely to be a bad thermostat, what model is the thermostat and heater?
Oct 12, 2017 | Honeywell Heating & Cooling
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
On my honeywell thermostat cool on keeps on flashing but ac dosent come on
On a Honeywell thermostat the flashing means that the system is in a delay to turn on the compressor. This is used to protect the compressor from coming on and off too often. The normal delay is about 5 minutes. After that the system should come on. If not there is s problem.
In order to help us help you we will need a little more information. What happens either at the inside unit or at the outside unit after the thermostat stops flashing "Cool"? Any fans come on? Do you hear a "KLUNK"? Any sparks? Please let us know so we can help.
Nov 20, 2011 | Honeywell Heating & Cooling
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
I can't get my Air Conditioner to come on ?
Clean the filters of the air conditioner. Also, if the unit has been running for a few years without proper maintenance you must expect lots of dust in the evaporator unit. This is usually easy to clean with compressed air.
May 21, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
