Question about Grilling
Where is the proper location for the igniter wire on the master forge portable grill
  • 4736 Answers
SOURCE: need manual for master forge 2 burner gass grill
If you contact Lowe's, the exclusive retailer for this imported grill, they will be able to provide you with the Owners Manual. Apparently, there were a bunch that made it through without having the Owners Manual.
Posted on Apr 01, 2011
  • 4736 Answers
SOURCE: Master forge grill won't light with 2nd propane
Here's the problem and how to solve it. When you opened the valve on the tank, you did it as you normally would. However, the new OPD Valve tanks will often shoot a heavy load of gas to the regulator and lock it up.
To hopefully solve the problem, do the following:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow), until the valve is fully open.
Then light the burner farthest for the tank first. Did the burner light and does the flame height
look correct? If so, light the remaining burner(s) the same way. Do all the flame heights look
correct? If so, you solve the problem. Remember to always open the tank valve Very, Very
Slowly.
If that didn't solve the problem, you will need to replace the Grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sell grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy grilling!!
Posted on Jun 28, 2011
  • 4736 Answers
SOURCE: The regulator has a hissing
You will need the replace the grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sells grills and accessories for about $30.00. Take your old one with you for comparison purposes.
After you install the new one, be sure to check it for leaks, as described in the grill's Owner's Manual. Also, and this is very important. When opening the gas tank valve, open it Very, Very Slowly (slow motion, slow). If you don't, the regulator will lock up and no gas will flow to the burners.
Hope this helped you and thanks for choosing FixYa. Happy Grilling!!
Posted on Sep 07, 2011
Kiko Dawg
SOURCE: Master forge grill leaks propane from regator
Not much info given here. But if I am reading correct, a gas leak is on the regulator unit which is attached to the gas line (hose). An entire gas line connection (propane is what I worked with-I'm cetain this will apply to natural gas also.) are less than $15 at your local Big Box hardware store (Lowe's/H-Depot). And they can be easily be replaced by snapping it onto your existing connection. By replacing the entire unit, you should not have to be worrying about any leaks or worse....harmfull accidents to you or your family. Just remember to check your work by applying some soapy (dishsoap) water all around the new connections and make sure no bubbles appear thru the soapy film, indicating a good tight seal.
Posted on Oct 04, 2011
SOURCE: gas grill ignighter
Does each knob have its own igniter and do all of them not work
Posted on Jun 22, 2013
Need a manual for Master Forge Smoker Model 32930
I'll save you the trouble. The master forge web site sends you to sears parts. Sears parts does not recognize this model number. This is another example of how Lowes sells mass produces products with little or no customer support. This item was for sale online but is no longer. Online sales is how many box stores remove items from stock that are either out of production or no longer being purchased by them.
Aug 15, 2015 | Grilling
Manual for Master Forge Smoker Model 32938
Go online to scribd they should have it
Aug 03, 2015 | Grilling
Where do we bring for warranty, grill purchased in O.C. FL on 6/22/14
The warranty is provided by Master Forge so you have to register your purchase with the company.
Oct 07, 2014 | Master Forge GGP-2501 BBQ Grill Burner...
Gas grill ignighter
Jun 21, 2013 | Grilling
Master Forge Smoker with propane gas tank will not ignite.
Check to see if your getting spark from igniter if no spark then check to see if your grounded and if so and still does not spark then replace igniter
Apr 19, 2013 | Grilling
Master forge electric smoker
There are no manuals to be found for the master forge model, that I have, but I did locate their website of the manufacturer
http://www.landmann-usa.com/
The heating element will not start until the timer is set.
Jun 24, 2012 | Grilling
Need instruction manual for Master Forge Vertical Charcoal Smoker and a thermostat
Hi bishop mi...
Go to the following webpage and download your FREE user manual for Master Forge Vertical Propane Smoker.
Use to cooking guide inside for thermostat settings.
Please take time to rate me
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
Sep 01, 2011 | Grilling
I need the manual for the Master Forge Gas Grill P3018
Where can I find the tub (bottom to the grill, where the charred pieces go, to the Master Forge P3018 as our has rusted out
Apr 26, 2011 | Garden
Grilling Logo
77 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
