Question about Poulan Garden
Have 2 chainsaws: one is 40:1 ration and the other os 50:1. Is there a mixture that will work with both saws?
    Problem Solver:
  • 9 Answers
Bolt will work! I would use 40:1
Posted on Jan 05, 2015
  • 132 Answers
SOURCE: Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Posted on Nov 15, 2008
dontbother10
  • 2220 Answers
SOURCE: I have a 240 Homelite chainsaw and need to know
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Posted on Oct 25, 2009
dontbother10
  • 2220 Answers
SOURCE: 18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Posted on Feb 19, 2010
Testimonial: "you'all have been very helpful.to even ask a question at a repair shop around here you must first hand them your wallet! Thank kindly"
dontbother10
  • 2220 Answers
SOURCE: Fuel mixture for a Mac 2-10 Chainsaw
Recommended mix (Super 2-10A) on the attachment; Please do not start this saw if the wind is blowing west or your grandchild is down wind.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1e87155fc8467cd988256b620016ca79?OpenDocument
Posted on Mar 16, 2010
dontbother10
  • 2220 Answers
SOURCE: Gas/Oil Mixture, 50 to 1 or ?
All major manufacturers recommend 50:1;
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil or
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
with the exception of McCulloch and Poulan 40:1 and Chinese chainsaws 25:1.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 18, 2010
What is fuel mixture for solo motosage 60135
Some say 100:1 with synthetics. I use synthetics on 80cc and larger saws in the range of 40/50:1. I never go higher than that....saws are just too expensive to be stepping over dollars to pick up pennies. A lot of people are trying to make mixing ratios like some kind of mystery voodoo. You'll always be fine in the 40/50:1 range with a good synthetic oil.
Jun 16, 2013 | Solo 654 Chainsaw Vintage Collectable Saw...
I want to confirm the ratio of fuel (unleaded petrol) to oil mixture for my Ryobi chain saw, model CS3816. Is it 50:1? What oil do I use?
Hi afs3...
Yes use the 50:1 oil to gas ration. 1 pint of 2 cycle oil to 6 gallons of gasoline.
Please take time to rate me
Sep 04, 2011 | Garden
I need to know what the gas to oil ratio is for a Husqvarna 372xp chainsaw is
Hi gducci1949...
Use a 50 to 1 mixture...1 pint of oil to 6 gallons of gasoline
Aug 22, 2011 | Husqvarna Garden
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Does this take straight gas?
Your saw most likely requires a gas/oil mixture. a 1:50 mixture (1 part oil to 50 parts gasoline) is common among newer saws. Some older saws (20 years or more) require a richer mixture, commonly 1:40. I recommend you consult the users manual for the saw.
Hope this helps.
Apr 26, 2011 | Garden
Is the oil gas mixture 32 to 1 standard on all chainsaws i have a mini mac 130
Only McCulloch and Poulan recommend 40:1. All professional grade saws except Chinese (25:1) recommend 50:1 or 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil. All saws, once adjusted for 50:1, (maybe not Chinese) start easier, are less likely to carbon foul, and allow your grandchildren to breath easier.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 09, 2010 | Garden
What is the fuel/oil mix ration for a 345 Husqvarna Chainsaw?
Page 19 of a 2007 Operator's Manual 50:1
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Does it run on 30 weight oil or a mixture of gas and oil?
It is an electric chainsaw, you need bar oil. Your manual says use 30 weight non-detergent. That is what bar oil is, with a few additives to help keep it on the bar and chain. It can be purchased at home centers and hardware stores and is less expensive than most motor oils. HTH
Lou
Nov 13, 2009 | Desa International Remington 12" Electric...
Garden Logo
41 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
