Question about Buckeye Nation Sales 8 Official Size Aca Regulation Cornhole Baggo Bean Bags Set 4 Royal
How do i apply the buckeye nation corn hole wraps? Do I varnish first? How to apply the large wrap without problems
How do you freeze corn on the cob
Hi Marjorie,I love corn,sometimes I cook mine on the grill,seasoned and butter,then wrapped in tin foil,here's a link on how to freeze corn on the cob. How to Freeze Corn
Jul 28, 2017 | The Kitchen Appliances - Others
Can I freeze slices of cooked corned beef?
Wrap it in glad wrap or similar , then freeze.
Mar 12, 2015 | Crock Pots & Slow Cookers
How to fix corn on the cob in the microwave
  1. Wet a paper towel, and wring out. Wrap the ear of corn in the moist towel, and place on a dinner plate. Cook in the microwave for 5 minutes. Carefully remove paper towel, and enjoy!
May 26, 2014 | Measuring Tools & Sensors
1984 f250 diesel fuel injector was installed without copper grommet on the base now where the fuel sprays in is full of ash burn off and no power very low idle and white smoke. How can I clean it out?
find a piece of dowel that will just fit inside the injector hole . get a piece of course emery paper and using a bit of masking tape stick one end to the dowel and wrap the rest around until it fits into the hole. Turn the dowel until all the carbon is removed from the sides of the hole. Next use a flat bladed screw driver and with a bit of emery wrapped around the end of the driver clean out the bottom of the hole until it is clean. Make sure that you use the correct copper washer as any old copper washer will not do (from diesel pump shop). If the carbon in the hole is bad after you wrap the emery around the dowel drive a nail in the end of the dowel and use a power drill on low speed to make it easier to turn the dowel
May 02, 2014 | Cars & Trucks
How do remove the faucet cover of a moen 7594EC
MOEN Motionsense Faucet Leaking????
Turn off the water valves beneath the sink. Cover the openings to both the drain and the garbage disposal. Use an allen wrench to remove the tiny screw holding the handle in place. Once the handle is removed, the leaking is most likely from the seams around the large plastic nut behind the metal-like plastic cover. You might be able to see water dripping from around the big nut. Remove the nut and wrap nylon plumber's tape (Costs probably around a buck at any hardware supply store) around the threads for a much better seal. Wrap the tape tight at least a couple of times around the threads.
Screw the nut back into place with your hand, then tighten with a wrench.
Place the cover back over the assembly, install the handle. You can apply clear nail polish on the threads of the tiny allen screw that holds the handle in place to minimize the risk of it coming loose and falling into your garbage disposal.
Jan 19, 2014 | Moen 7594EC Arbor Single Handle/Hole...
Is there any treatment for my calluses?
  • Salicylic acid. Additionally, your doctor may apply a patch containing 40 percent salicylic acid (Curad Mediplast, Dr. Scholl's Corn Removers, others), which is available without a prescription. He or she will let you know how often you need to replace this patch, and may recommend that you use a pumice stone or a metal nail file to smooth away the dead skin before applying a new patch. Salicylic acid is also available in a topical form by prescription for large areas.
  • Antibiotic medication. Your doctor may also suggest applying an antibiotic ointment to reduce the risk of infection.
  • Shoe inserts. If you have an underlying foot deformity, your doctor may prescribe custom-made padded shoe inserts (orthotics) to prevent recurring corns or calluses.
  • Surgery. In rare instances, your doctor may recommend surgery to correct the alignment of the bone causing the friction.
-http://www.mayoclinic.com
Apr 25, 2013 | Health & Beauty
I want to buy gift wrap but in large quantities. Anyone know where I can get this?
I've come across a couple of websites that sell gift wrapping but also offer large quantities at cheaper prices.
Try the Mr Gift Wrap site:
http://www.mrgiftwrap.com/
or Superior Gift Wrap:
http://www.superiorgiftwrap.com/
Feb 25, 2013 | Event Planning & Celebration
Wire 2003 avalanche
Cut off damaged wire ends and use a crimp type splice to resecure. Wrap each splice with quality black electrician's tape then tie wrap wires together, tie wrap wire bundle to secure points, then apply more electricians tape to bundle to water proof. Try and find some spiral wrap to protect the wire bundle as a top coat
Dec 29, 2012 | Cars & Trucks
Can cat5e cable be wire wrapped?
I tried the same thing once, the diameter and the twist make it useful only in desparate times when you just can't find any mylar wire to use. Been there, done that, now you have the T-shirt. I do use the wire for patching and repair but again it is just much larger than patch wire and not nearly as flexible.
Jul 15, 2009 | Computers & Internet
Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 26, 2009 | Technics Audio Players & Recorders
Buckeye Nation Sales 8 Official Size Aca Regulation Cornhole Baggo Bean Bags Set 4 Royal Logo
333 people viewed this question
Top Buckeye Nation Sales Sport & Outdoor - Others Experts
Are you a Buckeye Nation Sales Sport and Outdoor - Other Expert? Answer questions, earn points and help others
