Question about Crosley Audio Players & Recorders
Why does my crosley turntable not turn when I put the needle down on the record
    Champion:
  • 210 Answers
If you manually put the needle on the record, you still have to push the power on button. If you are using the auto on and the turn table isn't turning, either the band from motor to turn table broke (or came off) or the motor for turn table stopped working. All this is as long as there is power to the unit.
Posted on May 19, 2016
  • 17 Answers
SOURCE: Needle slides across the record on Crosley 5 in 1 player
you have unscrewed the suspension screw?
also check the needle for dirt and dust... try blue tacking a 5p coin to the top on the needle to give it a little more weight, if the needle stays in place then the arm balance if off, and unless there is a mechanism to adjust that on this turntable then i guess its a return!
Posted on Feb 12, 2009
SOURCE: Turntable does not turn
Try this - GENTLY move the phono arm to the RIGHT until you hear a click Tof course, do this after you turn on the power via the volume dial and set the other dial to"phono"). Doing this turns on the turntable when you haven't used it in awhile. This worked for us, hope it works for you.
If it doesn't work, you can check the belt by removing the tiny clip at the center post and gently lift the turntable platform/tray to peek at the motor and belt underneath. The pulley is on the right at the 2 o'clock position, the belt should be in contact with it.
Posted on Aug 07, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
  • 8404 Answers
SOURCE: Just got our Crosley cr249 turntable for Christmas
Increase the pressure on the needle.
Posted on Dec 26, 2009
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
My crosley keepsake turntable has been having a lot of static and the sound is very low, I can only hear it if I turn the volume all the way up. I'm not sure if the needle is the problem or there is s
I would check the wires to the cartridge. It might that one or more is off or loose.
If you turn down the volume completely and listen with a record playing you should be able to hear (with your ear) the stylus in the grooves of the record playing the track. Pick a loud (rock) record for this. If it does that OK the stylus is good.
Dec 26, 2014 | Crosley Keepsake USB Turntable
I just bought a replacement needle for a Crosley CR66 4 in 1 record player and now my records sound distorted and far away
It might be that you have caused an earth wire to the cartridge to come off or loose. Check the connections to the cartridge.
Jun 08, 2011 | Crosley CR248 Turntable
Jul 24, 2010 | Crosley CR248 Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
I have no clue how to play a cd there... I mean, the radio is no problem, i can turn it off and on, can search for a prog, no big deal. but how do i start the turntable? maybe someone even has a manual for...
to start a turntable press Start button and put an arm with a needle across record, if there is no start button, just put arm across record - it should auto-start; to play cd put it in and press play (play button shoud be near the cd slot, together with stop, skip and others)
Oct 14, 2009 | Crosley CR711-BK AutoRama Retro Turntable...
No sound coming from turntable
most likely this is the switch that selects among cd/tape/radio/record player. it could be the preamp circuitry in the player as well. it would not be the cartridge UNLESS you cannot see a little rubber 'seat' up inside underneath the cartridge that pushes the stylus tip out and down towards the record just a bit. if this rubber 'yoke' (seat) is missing you will get no sound even when you touch the needle tip when the record player section is selected.
Jan 29, 2009 | Crosley CR248 Turntable
Dec 26, 2008 | Crosley CR248 Turntable
Turntable speeds up/slows down constantly
hi, check the main board of your turntable.. maybe there a cold solder on the board ..u
Feb 15, 2008 | Crosley CR248 Turntable
279 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
