Question about Maytag MAT12CSD Top-Load Coin Operated Washer
How to change a neptune coin drop washer to get more money
3 Suggested Answers
SOURCE: CHANGING THE MONEY AMOUNT ON A DIGITAL COIN OP
I JUST HAD THE SAME QUESTION FOR A CUSTOMER REQUEST, I TALKED TO THE TECH SUPPORT AT MAYTAG AND THEY EXPLAINED THAT ALL YOU DO IS UNPLUG THE CONNECTOR CC FROM THE PRINTED CIRCUIT BOARD THEN SCROLL WITH THE CENTER BOTTOM BUTTON, TILL YOU SEE 600 DISPLAYED. (600 IS ZERO COINS, 604 IS 4 COINS, 608 IS 8 COINS, ETC.) THEN RECONNECT THE CC CONNECTOR AND PUT IT TOGETHER, SOUNDS SIMPLE ENOUGH. IM GONNA GO TRY IT
Posted on Oct 15, 2010
SOURCE: I have a Maytag Neptune
http://mikemerrittmotors.yuku.com/topic/838/Maytag-Neptune-coin-op-bypass
Why not just bypass it , as in this post above?
Posted on Apr 23, 2011
We have a Maytag MAH21PDDWW Washer when you put coins in it will not show you put a coin in but is you remove the maintenance cover you will see a * each time he put a coin in, is there a reset for this...
Hi and welcome to FixYa, I am Kelly. It is possible that the coin drop acceptor is dirty. See page 22 of this manual:
http://www.fowlercompanies.com/SM/Maytag%20Service%20Manuals/MAH21SERVICE.pdf.
On page 23 there is also a guide rail adjustment.
The processor will pretty much go into a tamper proof mode that will not accept any coins you input if there is a problem with the sensor bar or guide rail. I suspect you have a guide rail that needs adjustment. The manual explains the adjustment procedure on page 23.
Thanks for choosing FixYa,
Kelly
Sep 01, 2011 | Maytag Neptune Washer
Will not drain and stops but does not give an error code.
Check any pump filter and outlet hose for blockages, if all is ok check pump.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Maytag Neptune Washer
CHANGING THE MONEY AMOUNT ON A DIGITAL COIN OP MAYTAG WASHER MODEL# MAT12PDBAW
Sep 16, 2010 | Maytag MAT12CSD Top-Load Coin Operated...
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error code d5 on front load neptune washer
d5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Coins stuck in washer
I've used a butter knife or putty knife to pry them up.. just enough to allow the coins to slide back out. Just roll the drum back and forth with the knife wedged in there. Good Luck.
Jan 25, 2009 | Maytag Neptune MAH6700A Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Maytag MAT12CSD Top-Load Coin Operated Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
