Question about Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
I have a single hole delta handle that has good pressure cold but hot the pressure drops and only luke warm water on maximum
    Problem Solver:
  • 19 Answers
Water heater
Posted on Jun 23, 2009
Kitchen delta faucet doesn't get hot enough
Was it hot enough before the Delta? If so open and close the hot water valve (under the sink) several times as there maybe mineral deposits. I know you said the flow is the same on hot and cold but unless your version is a single handle model the problem should lie with the valve. If this is a cartridge model (cold & Hot together) then the cartridge may be out of align allowing the cold and hot water to mix.
Jan 18, 2018 | Delta & Single Handle Shower Faucet
I have a Delta scald guard shower faucet (older model). The cold water pressure is good but as a turn to hot the pressure drops to a drizzle. There are 2 other sinks and another shower upstairs and there...
It is more that likely the valve in the stem of your fixture, I'm assuming this is a single handle faucet. If you can replace the valve, you will cure your problem. I am giving you a link to how to adjust the hot water temp.
http://www.ehow.com/how_6531012_adjust-anti_scald-setting-delta-faucets.html
May 10, 2011 | Delta Home
We installed a new singel handled faucte in our shower and now we are running out of hot water. this never happened in this house before. we always have plenty of hot water, i called delta and they said...
The way the faucet cartridge is designed it will protect you from large changes in water pressure. This can happen if someone is useing the shower and someone else flushes a tolet there is a sliding valve in the cartridge that will close off hot water supply to protect you from getting scalded.If you are not getting hot enough water there are adjustment you can make to increase the maximum setting.
As long as you are getting good hot water supply in other fixtures in your house I doubt that changeing the water heater is going to help.
I think that you may have a defective cartridge and I would call delta again and give them another chance. They generally have very good customer service, and perhaps the one you talked do did not understand that you have good hot water supply elsewhere.
If you do not have hot enough water to shower valve that can eaisily adjusted by removing set screw that holds the handle on and remove the handle.If there is a white temp. limit disc on the stem then remove it. Slid the chrome sleeve from around the valve body off. You should see a disc that you can slid out a little and rotate to the left a small amount. This adjusting disc and its mating surface have teeth on them that mate. There should be marks on the valve and disc with a arrow on them to show which way to turn for hotter water.Reassemble and check.
If your water starts out hot and then gets cooler while being used and you still have hot water in other places then I think you have a defective cartridge. It should be under warranty. Hope this helps you some. Good luck and thank you.
Jan 26, 2011 | Delta & Single Handle Shower Faucet
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
I have an older single handle Delta shower valve, and I am only able to get good water pressure on cold water (which is opposite of the normal right hand). Can you suggest a solution?
A rebuild kit for a shower is pretty cheap for delta. the actual ball behind the handle maybe wore and not allowing it to seat properly and restricing water flow hot side.
Also if you take it appart the 2 washers and springs you might as well replace them also.
Replace washers and springs and the ball with shaft that handle fits to.
Shut off water before taking appart.
May 07, 2010 | Delta & Single Handle Shower Faucet
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
My shower has a delta monitor single faucet. And the flow has diminished so much that I am only getting few drops. The house has a lot of water pressure. What can I do?
Sounds like you have lost pressure on one side of the valve. ( either hot or cold ) Or the cartridge has gone bad. If you have hard water if probably is the cartridge. There are a couple of different series for your style of faucet.
The reason why you only get a few drops is the cartridge is pressure balancing. It is a safety device which prevents scalding if one side of the supply shuts down.
Please rate this response and Good Luck, Phil
Dec 30, 2008 | Delta T13420 Chrome Classic Single Handle...
Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
202 people viewed this question
Top Delta Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
