Question about Panasonic Televison & Video
Troubleshoot panasonic TC-L32C12N
Tv will not turn on red light flashes 4 times
SOURCE: TV won't turn on and red light flashes 6 times.
my sony 40 inch lcd tv flashes 4 times and wont turn on? Any ideas?
Posted on Aug 09, 2008
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
  • 8457 Answers
SOURCE: Panasonic hdtv, TC-P42X1, no picture,
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory setting.Now the tv should be working again.If it still have the same problems.The tv have a power supply board problems.That the board,where the a/c power cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jan 19, 2011
Panasonic 50 inch plasma th 50px80ua tv won't turn on and red light flashes seven times
Hi Steve, The link below is a YouTube video showing a panasonic television with 7 red flashes, Also there's videos down the right side of the link that may help as well... I hope this helps............CHEERS..
Panasonic TC P50S30 review seven led flash
May 01, 2016 | Panasonic Televison & Video
Should I get a flashing red light on my Panasonic TC-P42C2 tv even if nothing else comes on?
That is a known issue with the Panasonic plasma TV's, the flashing red light is a diagnostic light, you might hame issues with the internal power supply board.
Nov 17, 2014 | Televison & Video
Panasonic P42G15 has a 4 blink code and doesn't turn on
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Jan 05, 2014 | Panasonic TC-P42G15 Plasma TV
I have a panasonic model number TC-P42X1 and i have no picture or sound. and the red light flashes every 4 seconds none stop
I had a similar problem with my Hisense TV and I replaced the "Main Board". Got the part on ebay. Don't know if this will help.
Jan 02, 2013 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
18 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
