Question about DeLonghi ESAM5500
Milk not coming out of milk jug.
Why wont the milk come out of the milk jug any more. Goes through the process but nothing happens.
    Problem Solver:
  • 11 Answers
First make sure you have the tube seated all the way in, the one inside the milk jug. I had assisted with the same problem before and the owner did not put the tube back in after cleaning the milk container. Next add a little Petrol-Gel Food Grade Sanitary Lubricant to the O-Rings, should have two (a small black one and an orange one) on the machine that the milk container connects to. This will assist in creating a better seal. If either are missing then you found the issue. The O-Rings are critical to any pressure system, so keep them clean and lubricated. You can get Petrol-Gel at a restaurant wholesaler or Amazon.
Posted on Jul 03, 2015
4 Suggested Answers
mnwarfield10
  • 452 Answers
SOURCE: Our milk jug is not
we repair 07779933829
Posted on Jan 21, 2011
mnwarfield10
  • 452 Answers
SOURCE: We had a problem with
we repair call 07779933829
  • 30 Answers
SOURCE: delonghi magnifica promblems with water and milk
Frothing jug
For milk frothing issues, soak the milk jug cover in hot water and rinse several times. If it has a froth control that can be removed by sliding in the direction of travel towards the edge whilst jiggling it gently up and down. Clean off the little o-ring with a toothpick, be gentle. The control should easily slide and click back in place when done.
Froth still no good? Examine the milk coupling to ensure the o-rings are in the right spot and are pliable and undamaged. There should be an o-ring (usually green) on the top spigot, a (black) o-ring at the front of the bottom spigot and a (red) oring at the rear. The groove halfway along the spigot should be clear. Now with the toothpick and a hot moist cloth clean all the crud from the milk coupling, especially inside the smaller spigot. Check the tiny hole at the back of the larger spigot is not blocked.
Check the flow from the hot water spout is good. If not, there are internal issues, try descaling. If it is, test the frothing jug, if it is still weak either the jug cover or the milk coupling needs to be replaced. Get them to try a known good test jug at your local coffee service center to find out which, most will be happy to do this at the counter.
Posted on Jan 28, 2012
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
I have a Delonghi PrimaDonna ESAM 6600. Just recently it stopped frothing milk. To explain fully, I have outlined the sequence of the fault below and resolution steps that I have already tried.
That sounds like the spout is blocked, when the pump goes quiet it is because it has built up pressure and the solenoid is barely moving. Have a probe up the nozzle and see what happens.
Jun 29, 2015 | DeLonghi Coffee Makers & Espresso Machines
Milk jug is making the noises and steam is coming out but no milk?
I get this about every 18 months to 2 years. The solution has been to purchase a replacement lid for the milk jug. I've just paid (yesterday, as it happens) £16.99 for one online. This will be my fourth, and we're all set to go for another 18 months-2 years.
Btw, I've tried dismantling the lid to clean it etc, (many times), and it seems to make no difference. A replacement lid is what's needed.
Bob.
Oct 03, 2014 | DeLonghi EC Coffee Makers & Espresso...
Delonghi coffee machine ecam23. Milk comes out of jug when turning machine on and milk also comes out after the water when cleaning the spout on the jug.
I think the ECAM has a second solenoid at the front near the milk jug. That solenoid valve might be stuck open.
>> service agent
Oct 17, 2013 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica promblems with water and milk
Frothing jug
Jan 19, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
My Delonghi Prima Donna won't dispense milk only steam.
I've just had the same thing happen to me today. The one thing I noticed was there is a broken rubber ring which appears to have fallen from around the milk spout.
I'm off to the Service Centre tomorrow so will hopefully have some good news shortly...
Aug 23, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
DeLonghi ESAM5500 Logo
255 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
