Question about Yard Machines Cultivator
How do i check oil in gearbox? - Yard Machines Cultivator
Does a 2011 caddyTDi250 1.6 ltr need the gearbox oil changed when the vehicle has its regular service?its 5 speed manual gearbox,and is there a filter to be changed?
No but check with the dealer or your service/owner manual for the manufacturer recommended gearbox oil change periods.
There is no filter on the manual gearbox .
Whatever the manufacturer recommended period is for a gearbox oil change, change the gearbox oil twice as frequently as recommended to maintain it in good condition. If, for example, a change every 50000 miles is stipulated then do it every 25000 or so.
Nov 02, 2015 | Cars & Trucks
The hurliman tractor 110 XT the tractor in question broke a cog in the gearbox and when fixing we found the backend is getting air through the oil and airaiting and sometimes putting oil out the dipstick
gearbox oil not serviced and got too thin
oil getting too hot ..check or fit external oil cooler
a seal may have been leaking
wrong oil
is there gearbox breather
Mar 19, 2015 | Cars & Trucks
Refill manual gearbox with what oil?
gearbox oil grade SX75W/90 make is upto you
Mar 28, 2014 | 1999 Kia Sportage
The 4speed triptronic gearbox in my mitsubishi verada 2006model keeps jumping in and out of gears
Check gearbox oil.
Replace gearbox oil and gearbox oil filter, then retry.
Nov 07, 2012 | Cars & Trucks
How do I put gearbox fluid in ? Where is the level glass? I have a 1997 mitsubishi magna
Gearboxes usually have no oil dipstick / looking glass. On the side of the gearbox there's a bolt with (brass) washer. This is where the gearbox oil goes. To check the level is to stick one finger in downwards, when there's no oil at this level its usually too low.
On the bottom of the gearbox there's a similar bolt with washer to drain the old oil. The bolt can be magnetic - and can look a bit like a mushroom. Tiny particles from the gears stick on there - this is normal. Large bits of metal can be a cause for concern.
Always use the specified gearbox oil - wrong oil makes changing gears hard.
Jul 05, 2011 | Mitsubishi Galant Cars & Trucks
Engine oil draining away, no leaks, gurgling sound coming from gearbox breather..
Hello, you will find that the seal between the gearbox and motor is leaking, check your gearbox oil, it should be getting close to coming out of the gearbox breather (over full), do not ride, you will damage and burnout your gearbox.
Feb 17, 2011 | Yamaha SR 400 Motorcycles
New clutch it's already install but still shift noising
Make sure there is enough transmission oil in the gearbox, without oil the synchro's cannot work so gearchanges will be slow and cumbersome. If filling the gearbox oil dosent help maybe you have gearbox damage - have the gearbox checked out.
Jan 25, 2010 | 1990 Toyota 4Runner
HOW DO I CHECK MY VW CITI COLF GEARBOX OIL LEVEL? 1.8 - 5speed
about halfway down the gearbox facing the radiator is an allen key take this off oil should come out if not top it up
Jul 12, 2009 | 2003 Volkswagen Golf
Gearbox oil
there is no dip stick for the gearbox oil..there is a little rubber cover on a little tube sticking out of the gearbox housing. remove the rubber cap and fill through there.
Nov 29, 2008 | 1997 Honda Prelude
Transmission
Well, I'm not sure. Try changing the gearbox oil and try again. I saw on the other postings that most Audi gearbox problems pointing to a gearbox swap can be solved through oil change. I just had mine changed and it has reduced sluggishness and shuddering at low temperatures (from cool engine). It's a special gearbox oil you need to get from Audi, by the way.
Jun 14, 2008 | 2001 Audi A6
Yard Machines Cultivator Logo
42 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
