Question about HP Photosmart C4580 All-in-One InkJet Printer
RICOH printer won't print says ready but won't print?
Printer problem 2075
disconect the hard drive from the machine
Mar 05, 2014 | Ricoh Office Equipment & Supplies
ERROR CODE SC542 ON A RICOH SPC 242
Print Ready Temperature Error
?? The heating roller temperature increase during a set time is not correct.
?? The fusing temperature does not reach the print ready temperature within a
set time after the fusing lamp has turned on.
?? Defective thermistor
?? Incorrect power supply input at the main power socket
?? Defective fusing lamp
1. Check the voltage of the wall outlet.
2. Replace the fusing unit
3. Replace the fusing lamp.
**Execute "Engine Maintenance Menu" to recover the machine after
completing the recovery procedure. Otherwise, the machine continues to
issue this SC code and cannot be operated.
Jan 08, 2014 | Ricoh Aficio SP C232DN Laser Printer
Ricoh SP C221n not printing test page
You can install the SOM (Smart Organizing Monitor), it is a utility which can check the status of a printer and set up a printer
from a PC. This utility is executed from a printer driver.
Start the SOM to see the status of your printer..
Apr 11, 2013 | Ricoh Aficio SP-C210SF Printer
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
I need to print the configuration page for a Ricoh Aficio SP C222DN.
From the manual:
"To Print configuration page, turn the printer off then while pressing and holding [the stop/start key] down, turn the printer back on, holding the key down until the READY indicator flashes once. The configuration page will then print out"
Feb 28, 2011 | Ricoh AficioSP C222DN Laser Printer
Ricoh Aficio CL3500N Laser Printer How do I clear the print que from the printer?
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show STatus ready with 0 document
Jul 01, 2010 | Ricoh Aficio CL3500N Laser Printer
Can not print on my ricoh 2018
it sounds as if you have an IP address conflict, are you set to Dynamic or Static? if static set the last Octet ie:192.168.0.xxx to something at the top of your ip range, print out a config sheet from the Copier/MFP by going into user tools printer config page and print.
at the bottom r/h side is the host name of the printer typically with Ricoh it will be Rnpxxxx
set the hostname on your tcp/ip port to the host name ensure that you have dns information set on the MFP and your pc and also gateway info on both and that should fix the issue once your reboot the pc and MFP.
if this resolves your issue please rate me accordingly.
Thanks
Aug 06, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh CL2000 SC486
it is the problem your cartridge sensor chip.You change cartridge unite & buy new cartridge than solve it
May 30, 2009 | Ricoh Aficio CL2000N Laser Printer
No PPD available for mac
I used the Gutenprint driver for the Ricoh 220. It seems to be working fine.
Oct 08, 2007 | Ricoh Aficio BP20N Laser Printer
HP Photosmart C4580 All-in-One InkJet Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
