Dvd maker problems at 99% on hp computers
I have 2 hp laptops and they both have vista and dvd maker installed. both laptops, the dvd maker stops working after a couple of burns. it seems that dvd maker on hp computers have problems. is there anything i can do or will i have to get a new dvd burner software or a new dvd burner and if so, which one do u guys recommend, thanks for all the help.
Well the problem could be 2 fold , it could be the media you are using is going to fast , i had to change my settings to burn at medium to burn through or else it may stop at 99 the finalizing part, or 2 the temp area where it places the file while decoding, encoding etc etc could be getting filled quick, id recommend setting it to somewhere on the Hard Drive. As far as is there better ? yes ! i use Nero 9 now, love it, a lil bloatie but it does EVERYTHING you could need.
Posted on Jun 23, 2009
Burn windows 7 iso for hp laptop to dvd
OLD DV6910. note book. (circa 2007 ) near end of HP support.!
MS stopped VISTA this spring.
no, toshiba is no good, as are all other PCs makers disks no good. your PC us USA HP computer, its not from Japan.
sorry. only MS disks or best of best HP disks work.
the ISO from MS, how'd you get that, and when.?
the current link at MS needs valid RETAIL COA code to download it.(oem codes not)
The MS disk do not have all drivers need, to make an HP pc run..
sure it will load, but many things CAN be dead.
is your F11 restore dead too? (its VISTA, if you dont know)
power on , F11, f11, f11, f11 , hammer it. see the HP restore?
here is your official HP support page.'
https://support.hp.com/us-en/product/HP-Pavilion-dv6900-Entertainment-Notebook-PC-series/3725196/model/3740554
see? that
and all were shipped with VISTA, and F11 key restores
VISTA , there is no W7 drivers. from HP , zero
"i got image to burn.?"
so then what?, did you install W7?
and see all those dead chips? in device manager
did you get Ethernet working first so W7 can PNP the drivers automatically, /??
Things that can fail are.
HP special drivers for like , hot keys, that MS does not have
all HP apps will be missing.
and all drivers for old vista chips not supported under w7
see?>
MS loads. here is the path (using ms, disk and not HP media kit)
why not get the HP kit from HP???????
  1. Get MS w7 ISO, from MS using the $120 key, COA key,
  2. oops the HP key is no good, its OEM key/.
  3. down load ISO from MS.
  4. burn a USB stick or DVD from ISO, (Rufus, or imgburn free)
  5. boot PC using BIOS boot to DVD or stick as the case applies.
  6. W7 Loads, ok. (it runs sure, but...)
  7. W7 fails on Ethernet or wifi, one must work now or doomed, lacking other PC to find drivers from chip makers or MS.
  8. I wire up the Ethernet jack RJ45 cat 5 to my router.
  9. the internet is connected, i then let W7 find the drivers, good luck finding them all.. some can be missing, on 10 year old LT.
  10. if at wits end see this , on how to get them the HARD way.
  11. http://www.pcdied.com/Drivers.html
if you make a PCI scanner boot disk (or stick)
http://www.pcdied.com/pci-101.html
you can find most drivers. (mine never fails)
using he scanner on any PC we see all chips
and with vista drivers failing on w7
we go to the makers site and get the W7 driver
as seen here, PCI sniffer3 , I uses this all the time.
for exactly this reason.
the HP media kit DVD set is for VISTA only.
sorry.
Aug 12, 2017 | HP Pavilion Computers & Internet
Set msi 171f to factory defaults
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
hope this helps
Jun 26, 2012 | MSI MS-171F (937-171F44-001) Barebone
DVD wont burn with dvd maker gets to 99% then stops
HI THERE,
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq Computers & Internet
I have two problems with my HP compaq 6830s running VIsta business SP2 1) My inbuilt web cam stopped to work, and i have tried to uninstall and reinstall drivers with no luck. 2)The wireless card,...
If you upgrade your operating system like from windows xp to windows vista, you need to install new hardware driver for your computer like for LAN, webcam, WAN and others because the old driver is only compatible with the old operating system and not with VISTA operating system. Solution would are, download webcam and WAN driver for Windows Vista and install it into your computer. Don't just upgrade your computer because the configuration is not the same with the old operating system. If problem still exist, just upgrade the service pack from 2 to 3. There is available install for upgrading the service pack of each operating system. and surely all your hardwares will function.
Dec 29, 2010 | HP Compaq 6830s Laptop
Stopped playing CD'S and DVD's. (HP
If the CD/DVD disks play in another computer, then the CD/DVD hardware inside your laptop has "died".
Take your computer to any local computer-repair store, and get them to trouble-shoot, and, if necessary, sell you a new CD/DVD drive, and connect it.
May 07, 2010 | Computers & Internet
Can not burn pictures taken from a canon or kodak camera to a dvd
THIS IS COMMON PROBLEM - BECAUSE THERE IS NO INBUILT JPEG SOFTWARE WHEN WE BUY LAPTOPS- IT HAS TO BE DOWNLOADED FOR MP3, JPEG AND DVD BURNING PURPOSE
VNRao
Dec 27, 2008 | Toshiba Satellite A135-S2276 Notebook
X-PERT DVDMAKER USB2.0
Yes - same problem here -
Downloaded the latest drivers from http://www.kworld.com.tw/Support_download.aspx?id=241&d1=5&d2=1
and they worked with Vista initially, then when Vista SP1 came out - doesn't work anymore.... Dohhhh Waiting for new version / patch.....
Apr 14, 2008 | V-Stream Xpert USB 2.0 DVD Maker...
Drivers problems
Have you been to the makers webiste and downloaded driver specifically for vista? A lot of xp drivers wont work with xp.
Jan 08, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
129 people viewed this question
Alun Cox
David Payne
David Payne
