Question about Sharp 19K-M100 19" TV
How do you get to video without using a remote?
We lost our remote it is an old Sylvanina tv
My sintech tv shows key lock and I lost my remote
Without a remote control; you can't unlock it.
Mar 15, 2015 | Televison & Video
Use tv without remote
Go to Amazon.com and enter the make and model of the TV along with the words "TV remote" and you'll have lots of choices from $5 up for new and used remotes for that TV.
Jan 27, 2014 | Polaroid Televison & Video
My tv is stuck on the blue screen .
Go push menu button on the front of tv or the right side.Pick the video out,or tv.Or buy a remote.Website 1-800-Remotes factory Original.For the original remote.
Dec 18, 2009 | Sanyo DS27510 27" TV
Panasonic TV Model PV-C 1320
There should be a TV/AV button located with the front control buttons, press this & it should switch over to the AV source ie. your camera input.
Sep 02, 2009 | Panasonic PV-C1320 13 in. TV/VCR Combo
Have an old funai tv without a remote, please help to be able to watch tv,have a universal remote but do not know how it works, lost the manual
Tries this website.1-800-Remotes Factory original.U can buy an exact remote.Universal remote it impossible to get the old tv remote codes.
Sep 02, 2009 | Funai PY90VG DVD Player/VCR
I need to switch my tv to input without a remote
Hi
please use the menu button in your front panel then search the video, Air, or Cable selection!
Thanks!
Apr 10, 2009 | Sanyo DS27820 27" TV
Lost the controller for Pioneer rear projection TV
Try pressing the "Input" button the front of the set. That should allow you to change between the different inputs. The return button usually returns you to the previous channel you were watching - don't think it works for the input though. Also, depending on the model of the set you have, try downloading the PDF user or owners manual - it will tell you how to use the remote.
Jul 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
AVR-1802 config
If you can find old Handspring Visor or Palm III Pda ( usually5-20 dollars
in trift stores/pawn shops/used gear shoppes ) there is/was a program
for it called "omniremote" ( and perhaps others ) that you could draw the
outlay of the particular remote and copy the IR-signals from a working
remote, so if you could get those 2 ( one of the 2 PDAs , the program )
and borrow a working remote from someone, you could then record
and rescue your remoting ability with the PDA. IT is usually good idea
to "capture" any particular remote with this kin of setup before they die or
get lost. DId this with my TV remote, and once the TV remote died, I could
pull the PDA-omniremote recorded out and contiue using the TV like nothing
happened. Just a thought,
Dec 21, 2007 | Denon AVR-1802 Receiver
Sharp 19K-M100 19" TV Logo
18 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
