Question about Measuring Tools & Sensors
How to write explanatory notes? - Measuring Tools & Sensors
  • 641 Answers
Instructions
    • 1 Insert a superscript Arabic number at the end of the sentence which involves the explanatory note. This superscript number should fall just after the final punctuation of the sentence. This number corresponds to the footnote or endnote of your paper.
    • 2 Create a corresponding explanatory note number following the guidelines for endnotes or footnotes. Endnotes appear at the end of the written work under the heading "Notes". Footnotes fall at the bottom of the page in which the information is utilized.
    • 3 Write an explanatory note that remains simple and to the point. This note should only be about two sentences long and offer the reader a quick reference for further information. An explanatory note often offers further readings or brings up the arguments of another author. Only discuss information that is absolutely relevant or useful. For example: "Further work has been done on issues of ageism in John Smith's painstaking volumes on the hospice system."
Read more: http://www.ehow.com/how_10039812_make-explanatory.html#ixzz31l1Nv2MB
Posted on May 15, 2014
Where is thermostat located on a 93 ford escort 1.9 engine
the easiest way to find your thermostat is to
1.) locate you upper radiator hose (pretty self explanatory)
2.) follow this hose to where it enters the engine (the neck the hose is attached to on the engine is you thermostat housing)
3.) remove thermostat housing and replace thermostat ( NOTE: you WILL need a new gasket)
Sep 04, 2011 | Ford Escort Cars & Trucks
I have enrolled in the FixYa program to try and help if and when I can. My problem is i'm self taught on the operation of my computer, and there is alot I dont know. When I try and anwser a problem I cant...
Well, you're probably already clicking on the "Answer It!" button on the right side of the question (self explanatory) then you have to wait a bit for it to load (also self explanatory) and you should get to this screen pictured: es187.png This is also a self-explanatory page. If you're stuck on the main fixya page, just go to http://www.fixya.com/AnswerQuestions.aspx, it's so much simpler than navigating around everywhere on the website. I hope this helps!
May 03, 2011 | Sony Televison & Video
I have found compaq Evo N1000c notebook quick specs but not the same ports etc as mine. Full description is: series PP2140-SN 9X39KQDZCOBS-N1000C P 180X4 30 V C 250 AUST(OPERATING SYS.XP PRO. I am...
  • See http://h18000.www1.hp.com/products/quickspecs/11408_div/11408_div.HTML
  • 2 - USB 2.0 EHCI ports (1.1 OHCI Compatible) USB2
  • 1 - PC Card Slot Supports 16 & 32 bit, Type I & II cards PCMCIA Slot for anything PCMCIA
  • 1 - Fast Infrared Port Self explanatory, use with your mobile phone or an infra red printer port
  • 1 - Parallel Port 1 - VGA Port Printer Monitor
  • 1 - Microphone in Port Self explanatory
  • 1 - Headphone out Port Self explanatory
  • 1 - RJ-11 Port Telephone line modem
  • 1 - RJ-45 Port Network cable
  • 1 - 1394 Firewire Port for anything Firewire
  • 1 - AC Adapter Port Power in
  • 1 - PS/2 Mouse or Keyboard Port Self explanatory
  • 1 - S-Video Port S-video
Feb 01, 2011 | HP Compaq Evo Notebook N1000c
Left drivers door will not open from inside it does open from outside how to repair
you will need to remove inner door panel, either the handle itself broke where the rod connects,or the rod fell off or broke at the door latch, or the door latch lever bent or corrodded, the outer and inner handles use the same door latch but not the same mechanisms or rods to operate the latch. Once you remove the door panel and the inner dust shield with the window up look in the bottom of door for clips or a rod or broken parts. and note latch and handle for boken or bent and missing pieces. once you start looking it all becomes self explanatory.
Jan 15, 2011 | 1999 GMC Suburban
Overheating,valve near firewall that water hose from thermostat is broke
Pretty much self explanatory. the valve is called a heater control valve.
when replacing it don't pull on the hoses to the firewall or you can damage the heater core in the dashboard (a job you don't really want to do).
since there are several hoses there, make notes as to where the hoses go before removing them. Don't forget to put the small vacuum hose back on when finished. RE-fill the system with the heat on high and wait for the thermostat to open before closing it up.
If overheat was severe, replace the thermostat....they become unreliable after that happens.
May 27, 2010 | 1996 Jeep Cherokee Country
Looking for the calibrations for my samsung un46b6000 tv so i can fine tune my tv from the factory settings.
Hi dnankey
To answer your question;
If your looking for the procedure to get into the service menu, here it is;
With the power off and with the remote
Press in succession info-menu-mute-power
You should now be in service mode and the rest is self-explanatory
Make sure to note any values that you may change.
Have fun
Jan 19, 2010 | Televison & Video
SLOVOED CLASSIC ENGLISH_ENGLISH KEY
Hi
I need slovoed classic english explanatory registeration key version 3.1 my adress: albert.mccain1@yahoo.com
thanks
Nov 20, 2008 | Nokia N73 Cellular Phone
No suction
Flip the machine upside down and remove the four screws from the baseplate. Replacement should be fairly self-explanatory from there. If it's a self-propel model, note that the v-belt in the front WILL look loose normally, so it does not usually require replacement.
If you have a self propelled model, the belt you need ends in 035, if it's non self propelled it ends in 033.
Contact me if you need more assistance in changing the belt.
-R
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Measuring Tools & Sensors Logo
115 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
