Question about Dishwashers
Dishwasher wont stop running - Dishwashers
  • 258 Answers
Its probably the float switch. It's located in the base of the tub. Make sure there's nothing obstructing it and that it lifts up easily, not much detail in your problem but if it is running but not doing anything, then thats probably the solution
Posted on Jun 23, 2009
My dishwasher wont stop running
Stop running means continuous filling or washing!
Sep 23, 2015 | Bosch Dishwashers
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Dishwasher wont stop working
You will have to check if the dishwasher pump is constantly running . If the only way you can stop is by turning off the power supply, the float switch has tripped. This means ther is either water collected at the base of the dishwasher due to a leak or the float switch is faulty. ther may be an error code on the panel if this is the case.
Jul 18, 2012 | Baumatic 23 in. BDW13 Built-in Dishwasher
My dishwasher wont quit running and it leaks into the basement....any ideas?
It won't quit running or won't quit filling? If it won't stop filling then your float switch is bad or your valve is bad.
Jan 08, 2011 | Asko D1716 Built-in Dishwasher
you have leak anti flood activated pump will run even with door open need to find leak first then recheck operation
Jan 05, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher runs w/door open. Wont stop pumping water out
That was exactly my issue-I've tilted it 45d, emptied the tray and it works!
May 25, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
May 10, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Candy Dfi 85s intergrated dishwasher
candy dishwasher wont turn on , lights are out , it is plugged in any ideas please ?
Mar 02, 2009 | Candy DFI Plan Built-In Dishwasher
Lights blinking
I have a 3122 and had a similar problem, Lights flashing, humming noise and me standing there scratching my head! I emptied all the water out of the filter basket and then tilted the machine backwards (only needed about 20 degrees) and then the rest of the water drained all over the floor... about 1/2 a liter. Now its all good! and the missus is nun the wiser!
Jan 25, 2009 | Asko 24 in. D3112 Free-Standing Dishwasher
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Dishwashers Logo
186 people viewed this question
Top Dishwashers Experts
