Question about Goldstar MA-1012 Microwave Oven
Blown fuse in a Goldstar microwave Model: ER 760M. How can I replace
5 Suggested Answers
SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Posted on Jan 01, 2009
  • 4 Answers
SOURCE: Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Posted on Apr 03, 2009
  • 454 Answers
SOURCE: w have an old microwave runs great but the glass
Check craigslist or eBay.
Posted on Nov 06, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Goldstar Microwave: Goldstar
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Jul 28, 2011
What is the wattage for ER-4010
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
Sep 21, 2017 | Goldstar Microwave Ovens
Please I need the wattage of GoldStar microwave Model ER-868 so I can heat a heat pad for a sick animal
Wattage really doesn't matter much for what you want to use it for. Start with 2 minutes and test. If it's not hot enough add 1 more minute
Jun 09, 2016 | Goldstar Microwave Ovens
Our Goldstar Microwave is plugged in to a live source but, it no longer works; as if there is no power to it. MA 1080M (not the 780 M)
possibly the fuse has blown this will happen sometimes if there is excessive moisture or cockroaches or something strange in the power line the fuse used in microwaves is a slow blow fuse which usually compensates for these problems you also might have a high voltage problem or short note if you are thinking of replacing fuse if that is the problem remember microwaves work on very high voltages be aware of this if not confident please call repair technician keep me informed of the uotcome
Nov 06, 2009 | Goldstar MA-780M Microwave Oven
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Manual microwave oven model for ER-761 MD
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Some L.G. / Goldstar owner's manuals can be downloaded here.
Nov 19, 2008 | Goldstar Microwave Ovens
Goldstar MA-1012 Microwave Oven Logo
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
