Question about Maytag Atlantis MAV6000 Top Load Washer
My maytag front load washing machine #MAH8700AWW is leaking water at top of the door at end go cycle & now door won't latch
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
futureloginn
  • 734 Answers
SOURCE: Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE: maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Posted on Jun 30, 2009
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
Maytag front load washer will not unlock
Try unplugging the washer for 30 seconds then run a rinse and spin cycle. If it is still acting up you can remove the top panel and reach your arm down the front right side and find the door latch assembly. At the bottom up it is a pull tab. Pull that down and you will release the door latch. Image Whirlpool WP8182634 Door Lock Latch PartSelect
Feb 22, 2018 | Maytag MAH6700A Neptune High Efficiency...
I have a FE WCVH6260. Multiple times every cycle the machine door will unlock, and the cycle will stop. It will only restart when the "start/stop" button is pushed again.
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Aug 11, 2008 | GE Washing Machines
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Front Load Maytag Neptune won't spin.
check the board
is the resister thats burning r-11
if it is you need to change the wax motor lock as well
its the door lock found where the door latch goes in
ive included the part number 22002119
they should have told you
Oct 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune fnt loader Model# MAH8700AWW Ser# 12227145GR
I have the same problem. The technician seems to think it could be the water is not emptying during cycles. It keeps adding water as the cycles continue and therefore over flowing the tube when it spin. He thinks it could be a water level sensor. Not sure at this point.
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
My Maytag Neptune fnt loader Model# MAH9700AWW
I have a Maytag neptune mah8700aww
With mine the large grey rubber seal that seals at door slipped off! When this happens if you do not put back on correctly it will leak or even poor out the front center bottom of the door! My husband fixed it. But it still leaked really bad! I just took a couple of min. to refit the seal and it does not leak at all now! maybe your seal is not placed around the edge correctly! as it is easy to place it wrong! good luck!! keep my email address if I was helpfull!! We can always share problems and solutions for our neptunes in the future ! good luck
Anne Marie
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Leaking From the Door
possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
Dec 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
