Question about Weather King Heating & Cooling
Contact weather king manufacturer
The outside unit will not kick on.
RepairUSA
  • 50 Answers
SOURCE: Weather King contact info
479-648-4900 is the main line to the factory in Fort Smith Ar. Hope this helps, RepairUSA
Posted on Sep 03, 2007
  • 182 Answers
SOURCE: my weather king ac unit
drain line is plugged or drain pan is cracked
Posted on Aug 12, 2008
  • 116 Answers
SOURCE: is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
Posted on May 15, 2009
localwonder
  • 6784 Answers
SOURCE: not blowing cold air
Your in house core could have frozen over. check the core inside the indoor blower unit. it may have frozen over. this will interrupt the cold air function.
Posted on May 28, 2009
heatman101
  • 43501 Answers
SOURCE: my weather king furnace and ac will not kick on at
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jun 03, 2010
My outside unit will not kick on but in inside system will
Check the circuit breaker or disconnect for the outside unit. If it's not tripped then set the thermostat to make the a/c come on and see if the contactor in the outside unit is pulled in. If not then check the contactor coil. If it is then turn off the power and check the capacitor.
Jun 19, 2010 | Weather King 10AJA3001AH Air Conditioner
Weather King Heat Pump
Hey kellyrepp -- Three things to check quickly, so many things can be wrong, but i will try to help with the info you gave me.
The first sounds like your electric aux heat is not wired in or not working correctly , this should kick in when the heat pump cannot keep up with desired set temperature. For sure thats a problem
The second thing i would check is that the compressor for that unit is running. It should sound exactly like the one for the upstairs, the fan noise should be like a whrrrr , and the compressor should be a semi loud hummm.
Third feel the pipes on the outside unit that are on the outside of the unit (the unit for the second floor) Let the unit run for 5 minuites. Now check that the first floor unit pipes are the same tempereture. They are about 110 degrees or so, depending on the outside temperatur , be carefull not to burn yourself. If the lower unit is colder , the two most prominent problems would be #1 the compressor is not running #2 Low on freon.
Hope that helps
Jan 13, 2009 | Weather King 12AJA4801AH Air Conditioner
I'm trying to figure out if our Weather King system has a heat pump... how do I tell?
Your indoor furnace is weather king? If you have a a/c unit outside, it could be a heat pump, but you have to provide the model number on it.. If you do have a unit outside, when you call for heat does the outdoor unit kick on?
Dec 03, 2008 | Heating & Cooling
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Weather King AC
The motor of your air mover in the inside unit has failed.
It is responsible for circulating the air through the exchanger and your home.
This may be located in an attic space depending on the construction of your house.
Running the cooling with this not working could cause your outside unit to operate continuously or fail.
A more remote possibility is that the thermostat has failed and is only causing the outside unit to run.
Aug 19, 2008 | Weather King 10AJA6001AH Air Conditioner
My central air never kicks off
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Jun 09, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 12AJB60a01 - Noisy Clang at Startup like hitting metal lockers
Sounds like the compresser is going out on the unit the noise is internal the winding would not have anything to do with that noise maybe valves going out
May 23, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
15 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
