Question about GE 5 cu. ft. / 142 liter Chest Freezer FCM5SMWH
Gasket for a Ge freezer #FCM7DNAWH
I'm looking for a gasket for a Ge freezer mine is coming off
Frezzer keeps icein over
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
Why GE Freezers does not stop
A bad thermostat stuck in the closed position could cause it to run continuously.
A bad door gasket could cause it to do the same. But it would have to be really bad.
The door not fully going closed could be leaking warm air into the cavity causing the issue.
Jul 14, 2014 | GE Freezers
Gasket installation
I tried to re-initialize the freezer by unplugging it for a few seconds, then re-plugging it and turning the freezer back on, but, unfortunately, to no avail. NOT A SOLUTION EITHER, BUT AT'S A TRY.
Nov 22, 2013 | GE Refrigerator Freezer Gasket -...
Moisture on top of freezer near door
Change gasket or adjust door to assure a good seal.
Nov 04, 2012 | GE Refrigerator Freezer Door Gasket -...
We have a 20 cu ft GE chest freezer that will only cool to 20 degrees. What can I check to determine how to fix it?
Please check : - Your door ( gasket /seals, small air leaks) - Refrigerant level - Temperature sensor for failed
Regards,
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
Ge upright freezer, like 1988 - model # says ca 21 dkc rwh
by the time you have fixed any faults,you might just as well buy a new(er)more effecient f/freezer.cost you less in the long run(got mine from a garage sale,owners were moving far away....)
Apr 06, 2010 | Freezers
Lots of ice build up in freezer #TZ106921
It sounds like a bad door gasket. Check it carefully. Try placing a piece of typing paper in the door, close it and see if it stays, if not replace the gasket.
Good luck,
Gilshultz
Dec 03, 2009 | GE Freezers
Stand up freezer builds up frost quickly
It sounds like you may be on the right track here. If the gasket is old, hard, and brittle, it will allow moisture to be administered into the freezer, causing frost buildup. Not to mention, that old door gasket is leaking out a lot of cold air. Your best bet is to provide the model number (as you've shown here) and the serial number to an appliance parts store or authorized GE appliance parts outlet. They should be able to provide you with a brand new gasket. Removal and re-installation of the new gasket is fairly simple and you'll notice a big difference, not only in the lack of frost buildup on the inside of the freezer (especially in the summer) but you may even see a noted improvement on your electric bill as well!
I hope this helps and let me know if you need any further assistance! :)
Sep 22, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
How do I change the door seal on a gibson UR freezer?
The most important thing is to make sure the new seal is warmed up to room temperature so it is soft and workable. Since the seal on mine is attached to the top door there is nothing to gain by leaving the door attached. Working upside down would leave the door open longer than just taking it off.
If you still have food in the freezer just put blankets over the top until the door is back on. If you have screws holding the seal it will go much easier. Mine has plastic pins that break easily pulling them out.
Get the edges as straight as possible to avoid leaks.
Sep 19, 2009 | Freezers
Upright freezer
sounds like your freezer isn't maintaining a constant (cold) temp. A variation from cold to warm would cause your problems. Normal opening the door and looking for the ice cream over and over would cause a gradual increase in glacier activity in the freezer. I don't know of any quick easy fix-but wait, how about checking the door gasket? Get a piece of paper, close the door on it, move the paper all around the door, testing to see if you can pull it out easily (bad gasket), or does the paper not want to come out?(good gasket) If the gasket seems ok, it may be time to retire the global ice cream warming freezer countrycurt0
Aug 04, 2008 | Freezers
GE 5 cu. ft. / 142 liter Chest Freezer FCM5SMWH Logo
101 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
