Question about Camp Chef EVEREST 2 BURNER STOVE
Fuel leaks at pipe connection to everest 2 burner camp stove. Is there a different connection house or adapter?
Smell fuel leaking at pipe connection to unit, not at propane tank. This is where the 'O' ring seal pipe connected to the stove. How can I fix? Used it about 6 times since buying at REI last August. I camp a lot; 1-3 weeks 3-4 times a year. Had a p Primas for 25 years with a house connection. Is there a better hose connection to the stove. Like the cooking intensity on this, but this is the weak spot for me. The hose adapter to the fuel tank connection does not solve this. Any suggestion appreciated.
5 Suggested Answers
  • 70 Answers
SOURCE: two burner stove.one at a time it works good on
you have a gas flow problem check your regulator and also check all hoses make sure theres no foreign matter inside each hose.
Posted on Sep 18, 2009
  • 4736 Answers
SOURCE: I have miss-placed the legs to the Camp Chef
Sorry, Lally, we don't sell any parts on this website. Only information on how to repair or find parts. But, you can find the replacement legs you're looking for at Camp Chef. Phone 800-650-2433 and ask for the Parts Dept.
Posted on Mar 29, 2011
  • 4736 Answers
SOURCE: I connect the propane valve
Here's an easy solution. Turn the Tank Valve OFF, disconnect the hose from the tank and wait 5 minutes. Reconnect connect the hose to the tank and turn the Tank Valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the grill first. Once it lights, turn it to it's highest setting and light the remaining burners the same way. Once all are lit, does the flame height look as it should? Is so, you solved the problem. If not, then you need to replace the grill hose/regulator assembly. You can purchase one from any home center or hardware store that sells gas grills and accessories. Take you old one with you for comparison purposes.
If what I suggested solved the problem, remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you solve the problem.
Posted on Apr 09, 2011
  • 3239 Answers
SOURCE: burner 1 and burner 2
try cleaning burner 3 could be blocked , or it could be split , the air mix could be wrong you can move the air mix slider to give more or less air , see if the orffice is blocked . or you could try changing the reg but don't see that being the fault.
Posted on Sep 04, 2011
Help
I sometimes have this and I think it is just a bit of fuel left from a tiny leak. If it doesn't go out in a minute or two I pull out the tank and blow out the tip flame. With the valve off there is no more fuel going through.
Mar 26, 2014 | Coleman Vintage 1993 The Powerhouse 413h 2...
413e coleman stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Jul 28, 2013 | Camping, Backpacking & Hiking
How do you convert a coleman 425e into a propane stove
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
Hi I lost my regulator assembly for the camp stove model # 842-A100-W. Where can i purchase a replacement. & can you use a different one like for a coleman camp stove???
Hi bearsmommy19...
Yes you can use a generic regulator/coleman on your brinkman...just make sure the threads all match, if not, then adapters in brass can be bought at the local hardware HomeDepot,Lowes,etc.
Then you can install them to adapt your regulator to your brinkman grill
Please take time to rate me
Aug 28, 2011 | Brinkmann 842-A250-0
Gas smell by back of stove and burner amana model arg7302ww had applicance repair guy that used "lighter" and said no leaks, $65, and still smell gas in both spots...enough to make me dizzy,...
Firstly, The guy who tested with a lighter needs reporting to the professional body that qualfies gas engineers (In the UK he would have to be "CORGI registered" I presume you have similar in the US). Had he found a substantial leak with his lighter he could have exposed you to a lethal explosion.
Here is a vers safe ameture way to see if you have a leak:
First: Vevtilate the room so there is no smell of gas, open all the windows and doors and let the air blow through. If there is any hint of a gas smell, just call out a gas emergency service.
It's unlikely taht your leak is that bad and if you are happy that lighting the stove is not going to cause an explosion, do the following:
  • Turn the gas off at the main
  • Immediately, go to the stove and light the smallest burner
  • Time the interval between lighting and the flame dying out for lack of gas
  • Turn the burner control to off
  • Turn the main back on
  • Light ALL the burners (It may take a moment) to ensure any air is evacuated from the system
  • Turn OFF all the burners
  • Return to the main and turn that off
  • Wait 30 minutes to an hour
  • Without turning the main back on, turn on the small burner and time the interval it ramains lit again.
  • Turn the control to OFF
The time it took the burner to go out immediately after turning off the gas and the time it took after your 30-60 minute wait SHOULD be the same.
If it took less time to go out after the wait period, it's because some gas leaked out somewhere.
If the time was the same you have no leak.
If this demonstrates you DO have a leak, my advice would be to call out the idiot who tested the stove the first time and go through the test with him. Then, demand a refund on pain of you reporting him for a health and safety violation if you don't get your money back. Now throw him out of the house.
Call out someone who is more competent (Shouldn't be difficult, a trained chimp would probably out perform this guy!)
You can test the new guy's work the same way before he leaves too!
There is NO WAY that a leak like this should force you into a replacement stove unless someone can demonstrate what the failing component is and that costs more to replace than a new stove.
Hope all the above helps. Please drop a comment on this thread to let me know how you got on, or if you need any further advice
Jul 22, 2011 | AGA Legacy 44" Electric Kitchen Range
I have a ge Profile propane range.at times I get a smell of propane near the range.we checked the connections at the back of the stove & they seem to be fine.the smell seems to be stronger at times as...
Open up the range top and check the piping connections right up to each burner. Use soapy water and a small brush to do this safely. Chances are you have a leak. J.
Jul 05, 2010 | Maytag MGR5770 Gas Kitchen Range
Gas odor
then u probably have a leak did you test for leaks?
Mix some dish soap any water and brush it onto the connections...bubbles mean a leak, if its not the connections you did and the pipes are not new but the unit is then it could be the unit.
test any connection you can get too.
Mar 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Constant gas smell. had PG&E come and check. The determined the leak is coming from the stove somewhere, not from the gas line
i have a 2 year old stove, and i smell the gas every time i walk by it, i when on a mission to find it, and it was coming from the safety valve in side the oven, right where the burner sits on. open the oven door when all the house doors and windows are close and smell it and check if is coming from the in side of the oven, not all gas leaks are from the same place, that's like a hands on job, to find a gas leak. you can also check every valve with some soupy water this are the ones that suplie gas to the burners.
Dec 05, 2008 | Viking Kitchen Ranges
Camp Chef EVEREST 2 BURNER STOVE Logo
142 people viewed this question
Top Camp Chef Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Camp Chef Kitchen Range Expert? Answer questions, earn points and help others
