Help washer wont start
My washer is an indesit w143 front loader we changed the brushes around 2 months ago then over the last 2 weeks it started to trip the electrics off then about 2 days ago i put it on a wash it filled but then it was stuck on the programme so i turned it off and reset it now it just wont do anything the light comes on and flashes like it should do as if it knows what you want it to do but it just wont start i would be gratful for any help
many thanks helen
  • helen37 Nov 06, 2007
    great thanks for that i will test it then let you know how i get on
    thanks helen
  • 76 Answers
The reason for it triping the electrics is because it is earthing out, so you will need a test meter to find out where it is earthing, it could be that the heater was earthing but now has gone open circuit, if this is the case then the machine would not start, so I think the heater has to be the first thing to test.
Posted on Nov 05, 2007
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
The kirby wont start no power
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Jun 20, 2010 | Kirby G6 Bagged Upright Vacuum
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Feb 10, 2010 | Washing Machines
Washer wont do anything after it fills
try your outlet,,plug something else there to see if you have current if so make sure breaker is 15 amps or better with washer on line alone..if good bad door switch..
Dec 25, 2008 | Indesit W 123 Front Load Washer
Hey there...
The only thing that can cause this is the filter is blocked, or its needed of a service....
Its not that big a deal but its something in all front and top loaders, it needs a good service at least once a year...
Hope this helps you.
Jun 12, 2008 | Indesit WA 115 Front Load Washer
Indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Mar 31, 2008 | Indesit W 123 Front Load Washer
WIDl126 - door lock and easy iron flash
worth trying this! make sure the drain hose is only down the waste pipe about 6 inchs, and up off ground level about 24 inchs ie. 2 feet.If that don't not work it could be faulty pcb board!let me know.bye,close,ire.
Dec 23, 2007 | Indesit W 123 Front Load Washer
Washing machine not spinning
Check your brushes in the motor. Have a good torch with you. You will see the brush holders and the brush sticking out. With a small screw driver lift the brushes back up into the holder to see if you have any travel.? A front loader can cut out a set off brushes about every five years.
Nov 30, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
