Question about Ovens
Maytag gas oven model #CWG3600AAB won't restart after pre-heat. will only start again when cooled all the way down
  • 5 more comments
  • nsmith242 Jun 24, 2009
    I replaced the igniter and the valve and the problem is the same. The resistance of the igniter out of circuit is 135 ohms. The resistance of the valve out of circuit is 1 ohms. Am i using the correct replacement parts? What should the readings be when cold?
    Hi
    i did not have a chance to check the current as yet but here is more information for you to be able to help.
    when i first turn the bake on the oven will lite.i allow to heat to 100 degrees and shut down. i turn on bake imeadiatly the igniter glows and after about 1 minute i smell gas but the oven will not lite.The oven will only lite again once i allow to cool before restarting. Is there a reason why i am smelling this gas? This has been the case since i installed the oven in December 08. The broil will remain lit but once you shut it down will not restart untill cool.
    maytag model # CWG3600AAB preheats ok but will not restart once the flame goes out. The igniter will glow, there will be a smell of gas but the flame will not re-lite.I have change the igniter and the valve but problem remains.The resistance of the valve is 1 ohm and the igniter is 135 ohms out of circuit.This is a new oven and the problem was there from day one.In the broil position the oven function ok.
    Hi Taran
    my model #is CWG3600AAB serial # 25533588NG .
    Can you confirm the part and what is the part number at the web site you reccomend?
    Can you also tell me what should be the resistance of the igniter out of circuit. ?
  • nsmith242 Jun 25, 2009
    Hi Taran
    No i have not replace that part. can you tell me how it is represented on the drawing and can you identify the part number on the appliancepartspros.com site so that i can order and replace. i will do anything to resolve this problem.
    My problem is still the same as posted.There must be a solution. Is it possible for the replacement igniter to be faulty. iam using LP gas and the resistance of the igniter when cold is 135 ohms.
    Hi Pumpkinman i will order a new igniter and will get back to you with the result.
  • Ovens Master
  • 3,866 Answers
Check thermostate/ check and r/o igniter with a R/o of therm first. If its preheats okay then does not keep or upper temp R/o therm. If it does not ignite gas and you smell gas check ig.
Thanks for using fixya i hope this helps
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 25, 2009
  • 1,165 Answers
Sounds like a week ignitor new or not my bro had the same problem put new regulator on and ignitor and BOTH were bad from store.brandnew
    Sergeant:
  • 296 Answers
Hi
all i can suggest u ve to replace the oven glow bar igniter.
Since there is power getting to the stove, it is likely a bad Maytag gas stove igniter. This is a fairly common problem and repair.Most times when a Gas oven won’t bake, it’s because the gas bake ignitor has gotten weak or it’s just burned out. The ignitor is a small round or rectangular device located near the burner. The ignitor is wired in series with the gas safety valve.
When the ignitor is cold, it has a lot of resistance, meaning it gets most of the electricity in the circuit. As it heats up, its resistance drops. This allows enough electricity to heat the bi-metal strip in the gas safety valve, which then allows gas to be released to the burner assembly. The gas then gets ignited by the glow-bar ignitor. The ignitor glows the whole time the burner is on, keeping the gas safety valve open. The thermostat senses when the desired temperature is reached, and cuts off electricity to the gas safety valve and ignitor.
If this ignitor is weak or burned out, it won’t heat enough to lower its resistance to the point where the bi-metal strip gets enough electricity to heat up and allow the gas safety valve to open, and it will not release gas to the burner assembly. When this happens, you may have to replace either the ignitor or the gas safety valve. Many times it’s the ignitor that is to blame, and cheaper to replace. You can buy a replacement Maytag Gas Ignitor and do the repair yourself if you are savvy enough.
CAUTION: before you start work on any gas range, oven, stove or cooktop, be sure to cut off the electric power supply and close the gas supply valve to shut off the unit’s gas supply.
chek ths sites
http://www.apwagner.com/index.php?main_page=page&id=1177
http://www.ignitors.com/oven-ignitors/
hope u will b helpfull
regards
Posted on Jun 23, 2009
  • 10,515 Answers
In most of the models, there is a "Flame Safety Circuit".It would be on the D.S.I board.Once replaced, i guess would fix this problem.
You can purchase them from many sites like :-
http://www.appliancepartspros.com
Buy it from the above site as i believe they have 30 days refund option.If unable to fix the issue, they would return the amount.
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 24, 2009
  • taran_2005
    taran_2005 Jun 24, 2009
    Check ....Have you ever replace this part :-
    http://www.appliancepartspros.com/partse...
    Confirm the same by looking into your Oven.
    Hope i helped you.
  • 241 Answers
Goto
http://www.frigidaire.com/default.aspx
u will find the answer
  • 296 Answers
you may have a faulty thermostat or clogged burner ports.
follow the steps:-
  1. step 1:Remove the oven door. It may just lift up and off the hinge arms, or you may have to unscrew it from the hinges.
  2. Step2Spread several sheets of newspaper on the bottom pan to absorb soap and water that may spill during cleaning.
  3. Step3Locate the upper burner, attached to the roof of the oven. Remove the burner cover, if there is one. Use a screwdriver or a nut driver and socket, as required.
  4. Step4maytag gas oven model #CWG3600AAB won't restart - 214_a1.jpgClean the burner flame openings, using a scrub brush and warm, soapy water to remove the surface grime, and the end of a paper clip to poke out dirt that has collected in the openings (see illustration). If the surface grime is particularly stubborn, spray with oven cleaner and let it sit for 15 minutes. Then rewash the burner with warm, soapy water, and again clear the flame openings with your paper clip.
  5. Step5Remove the newspaper and lift out the bottom pan. The lower burner will be underneath. Clean the lower burner, following the same procedure described in step 4.
  6. Step6Wipe up any water or dirt that collects under the burner. Let all the parts dry thoroughly, then reassemble the oven.
hope it works
Oven heats & then beeps code F2EO then stops heating
F2 - E0 Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Here is that part to order.
Jun 19, 2013 | Maytag 30" Built-In Single Electric Wall...
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
My Maytag oven works when it wants to when I heat it up it take forever and then sometimes it will stay heated at the temperature I set it at and sometimes it just quits and wont start heating again after...
The number one problem for these ovens is the ignitor. This one is your ignitor according to your model number When it is weak it is intermittent. Sometimes you can get the oven to work if you give it a swift kick. This video explains how it works:
The next likely suspect is your oven sensor. That is the link to your oven sensror according to the model number you posted. Here is a video which shows how to check it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 14, 2011 | Maytag Ovens
Maytag walloven m# cwg3600aab Try to start. F5
Hi and welcome to FixYa, I am Kelly
I checked both types of Maytag oven fault codes and they both come up with the same fault.
Sadly this is telling you the Clock assy / ERC has failed.
F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
The clock assembly is item 1 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=42821
Close up view(s) Click pictures
http://www.appliancepartspros.com/part_details.aspx?part_id=4009450
Thanks for choosing FixYa.
Kelly
Oct 06, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven takes a long time to preheat
If it's electric ... could be one of:
1. Bake or Broil element has gone bad. The Broil element is cycled on and off during Bake pre-heat, so if it is bad this would slow down pre-heat. Does Broil work OK? (If gas, may be ignitor problem).
2. Temperature sensor problem. Does the oven eventually get to the right temperature?
3. Control board failure. If #1 and #2 are ok ... we see the control board fail and cause these symptoms. If so, we may be able to help you, we repair control boards at
www.fixyourboard.com.
Sep 29, 2009 | Maytag Ovens
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Ovens Logo
215 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
