Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Can't figure out how to put brush back on - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
I have a Upright Hoover Elite. Can't get belt back on right.
The belt loops over the motor shaft and the brush roller. Verify that the arrows on the end caps of the brush roller are facing DOWN or you will be doing the job over again. Start with the motor shaft and stretch the belt to allow the brush roller to seat. A new belt can require a strong pull on the brush roller to get it seated.
Nov 16, 2016 | Hoover Vacuums
The rotary brush stopped spinning. I believe its
I have seen belts wear faster than that, believe it or not. Here is a link to the belt you need and a link to the manual:
Bissell Health Home Replacement Belt
Bissell Healthy User Guide (PDF)
Nov 17, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Cannot figure out how to install brush belt on a bissell proheat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
twywt
Jan 16, 2009 | Bissell 8910 ProHeat Clear View Upright...
How to replace Riccar Roller Brush Bristles.
On the belt end, there is a clip #59 to remove then you can take the brush roll apart, replace the brush strips and put it back together.
Jan 02, 2009 | Riccar 8850 Vacuum
I have no idea how to put the belt back on
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Fantom fury vacuum
HOW DO I CHANGE THE BELT ON THE FANTOM® THUNDER® AND FURY®? a.gif fantombeltchange1.jpg
  1. Unplug the machine.
  2. From the front of the machine, remove the collection bin.
  3. Facing the back of your vacuum, remove each of the Philips head screws located above each of the rear wheels. (Figure 1)
  4. To remove the base cover, place your thumbs in the two screw holes in the back of the machine. Push forward and up on the screw holes to disengage the 3 cover locking tabs. Put the cover off to one side, and go to the front of the machine. (Figure 2)
  5. Check the drive arm for any black streaks which indicate residual rubber from the last belt. The drive arm is located on the right side of the motor. The easiest way to remove any residual rubber is with some nail polish remover on a rag or with steel wool.
  6. To attach a new belt, remove the brush from the base of the machine by pulling up straight up with two hands.
  7. Take the new belt and hook it over the steel drive arm. Pull back on the belt slightly, to create some tension.
  8. Put the brush inside the belt loop so that the track for the belt is aligned with the belt itself.
  9. Replace the brush by aligning the metal end so the points face downward. (Figure 3)
  10. Rotate the brush by hand to check that the belt is running freely and easily in its designated space between the bristle.
  11. Replace the cover by placing the nose in first. Once in place fasten with the two cover screws and then replace the collection bin.
May 13, 2008 | Fantom Vacums Lighting Canister Vacuum
Hi....Need Help please....
Put the belt on the brush roll, place it in the nozzle, make sure the belt is in the center, turn the big knob on the front until it locks, then install the nozzle on the vac., turn the knob in the other direction, and it will be put on the pulley.
May 11, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Mar 22, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
18 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
