Question about Midea MDC-45AE Dehumidifier
What is th best setting for my dehumidifier?
I can't find the manual and want t know which % t set it at? % to set for operation
Clean frigidaire dehumidifier cooling coil
Hello Friend, thank you for your post!
I see that you would like to know how to clean the coils on your Frigidaire dehumidifier and that it is no longer collecting water. The best way to clean the coils is by using a brush attachment from your vacuum. Typically there are one or two reasons why your dehumidifier is not collecting water. Either the setting might be set too high or not enough moisture in the room. I suggest changing the set point to a lower setting. As humidity drops in the room the amount of water will decrease and very little water may be generated even when in continuous mode. If these basic troubleshooting tips prove ineffective, then your dehumidifier may possibly have system issues. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best - Z
Sep 02, 2014 | Frigidaire 50 Pint Capacity Dehumidifier
Den 500p dehumidifier fan works but compressor does no activate
Phil, it may simply be a case that you have the humidity extraction level set to high. Try lowering it to 32 - 35%. If your unit is not equipped with an LED Screen, set the manual control to Maximum.
Also, remove and check the air intake filter, to see if it needs cleaning. And maintain at least a minimum of 12 - 18" of clear air space around the entire unit, while in operation.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | DeLonghi DE500P Dehumidifier
Whirlpool Gold Dehumidifier -The lights are all working, no fan? Is there a reset ?
You have what Whirlpool calls a Type 3 Control Panel. If you don't have the unit operating in Continuous Mode, the fan will operate only, when the compressor turns on to extract the humidity, based on the level of extraction you have it set on. If you haven't already,.set the control on Maximum and Continuous Mode.
If that doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. After the time has elapsed plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout, allowed the unit to reset itself and revert back to the original factory settings. If so, you can set the controls as you like.
To further assist you, I have an included a link to your Owner's Manual, in case you have misplaced your. You can download and print it for future reference.
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%201188826.pdf
I hope this helps you to further troubleshoot and solve the problem. Please let me know. Thanks.
Jun 21, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
My dehumidifier is not collecting water what can i do to fix it? the model #99701
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 primary reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Kenmore 54501 Dehumidifier
Have classic dehumidifier model#CDR4500E. Can't adjust it automaticaly to come on or shut off. Don't understand the keypad fuctions, booklet to confusing.
Your dehumidifier preset default humidity level of 70%. Which is rather high, if you're using the unit in the hot Summer months. You can override this setting and lower the humidity level in increments to as low as 35%. Which is ideal during hot, humid weather. The Air Down button lowers the humidity level.Once the level is set, the unit will cycle ON and OFF as necessary, to maintain the level of humidity.
I have looked at the Owners Manual for you unit, and it's very thorough. But, I can understand, if you're not familiar with how the units work, it could be confusing. Page 5, is very informative on how to operate the unit, as far as setting humidity levels, which is what's important. If the operation of the unit continues to be a problem for you, contact Danby Customer Support 1-800-263-2629 and they can walk you through the procedures, while on the phone with them.
Hop this helped you. Please let me know. Thanks.
May 18, 2011 | Danby DDR2509EE Dehumidifier
Unit runs but doesn't collect water and there is a lot of water in the basement. Have had dehumidifier for two weeks and was working well before.
Keep in mind, that a dehumidifier only draws humidity from the air, if the level of humidity is higher than what the controls are set on. For instance, if you have the dehumidifier set on 65 to 70%, that's a high level of humidity to maintain in a house. If you have it set for 35 or 45%, that's a low level of humidity to maintain in a house. Which, generally is what you want to maintain in the hot, humid summer months. Also, it's not uncommon on some dehumidifiers for the fan to almost run constantly. It's designed to keep the air moving, in a effort to detect when the humidity level rises.
Also, a dirty air intake filter makes the unit strain to keep up and can't take in moisture as it should. So, if you haven't cleaned the filter no is the time to check and clean it. And while your at it, clean the cooling coils too. Since it sounds like this unit has been working hard for 2 weeks.
The easiest and best way to test a dehumidifier at home, to see if it's working properly. Is to place it in the bathroom and turn the shower ON and don't operate the bathroom's exhaust fan. Set the humidity level low (45%), turn the unit ON and close the door when you leave. Wait 15 to 25 minutes and check the water collection bucket. If there's water in it, it's working as it should.
For more information on the proper operation of a dehumidifier, go to the Tips section of Fixya and look up "Taking the confusion out operating a dehumidifier".
Hope all this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Dehumidifiers
New unit, try using in basement. nothing happen, should humidity settings be high or low? Dose humidity level be high? In the bucket whats the plastic cup about? do something alow water to enter bucket?
If you trying to remove humidity, the setting or percentage of humidity to you want to remove should be set low. it's actually the humidity that will be left in the air. In the Hot Summer months, you want lower humidity, as opposed to the Winter months, when you want higher humidity.
"Plastic cup inside the bucket" - that's got me stumped. But, I suspect, it may be a float valve to turn the unit off, once the bucket reaches the full level. The water enters the bucket through a drain tube or hole from inside the dehumidifier, above the bucket.
By best advice, since this is a new unit, that you recently purchased, is read the Owners Manual/User Guide and become thoroughly familiar with the proper operation of your Dehumidifier, as well as how to properly maintain it. As, they aren't maintenance free.
Apr 15, 2011 | Haier DE65EJ Dehumidifier
Just wanna know how to set the temperature on it
dehumidifiers do not have a temperature control, rather, they have a humidity control. usually you set the humidity control to go off when the level of moisture in the room reaches normal (approx. 25-35% winter;38-55% summer). Best way is to run it at full on for 1 to 4 days (until you know the moisture level is how you want it), then turn the knob until the unit goes off . This will be the ideal setting. Goodluck<Macgivor
Jan 16, 2010 | DeLonghi DDE40E Dehumidifier
Can I set my dehumidifier to turn cycle on and off while I am traveling
Normally a dehumidifier will run based on the humidity found in the air in the room it is located in, although many can be set to run all the time.
I don't believe your model can be set to run next Tuesday, Wednesday and Thursday because you will be home and th NOT run next Friday and Saturday because you will be traveling, for example.
Your machine should run on automatic until the bucket fills with water at which time it should stop running until you empty the bucket. Many buckets offer the feature of adding a drain hose you can run to a drain somewhere. Some people have a floor drain they use for such purposes. Others I have known sit the device on the counter and drain into a sink or in the bath tub and drain that way.
For best dehumidifying results, you should run your machine all the time.
I hope I have answered your quesiton. Thanks for considering FixYa.com
Jan 06, 2010 | Frigidaire FDL50R1 Dehumidifier
Unit blows out cold air while on dehumidifier
Liz; Check for a fuse somewhere in the heat circuit. The master breaker in the house panel also
Jul 07, 2009 | Dehumidifiers
Midea MDC-45AE Dehumidifier Logo
63 people viewed this question
Top Midea Dehumidifiers Experts
jasbo
jasbo
Andrew Taylor
Andrew Taylor
 Russ Hill
Russ Hill
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
