Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Electrolux refrigerator panel dark - Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Friend,
I understand that the panel is dark on your Electrolux refrigerator. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power to your refrigerator, if the panel is still dark, I recommend contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Posted on May 16, 2014
How do you fit door panel
Thank you for your inquiry, friend!
Based off what you have described you would like to know how to fit the door panel on your Electrolux refrigerator. What kind of panel do you want to install? If you could provide a little more information I may be able to assist you further. -Matt
Mar 16, 2015 | Electrolux Refrigerators
How do I change freezer settings on electrolux model# EW28BS85KS
Good Morning Colin Humphries, thanks for your inquiry!
I see that you are having difficulties with your freezer settings on your Electrolux refrigerator. It could be a miscommunication within your control panel and I would suggest resetting your refrigerator. You can do that by unplugging the power cord for roughly ten minutes. If that does not help correct your issue you may need to have a technician out to your home to diagnosis and replace electrical components on your refrigerator. Hopefully this information is helpful. -Matt
Jan 21, 2015 | Electrolux Refrigerators
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
The power went off then turned back on but the electrolux side by side refrigerator control shows off how can I reset back on.
Good Afternoon friend, thank you for your post!
I understand that your Electrolux refrigerator is not coming on. Is it displaying any codes on the panel? Would you be able to provide me with your model number that way I could research additional information for you please? You can locate your serial tag (which lists your model number) on inside wall on the right hand side. I look forward to your response. -Matt
Sep 16, 2014 | Electrolux Refrigerators
Display panel on Electrolux wave touch French door refrigerator will not adjust temperature. Ice or water won't' dispense either.
Hello friend, thank you for your post!
Based off the information you are describing it sounds like your control panel is locked. Can you check to see if the control lock is lit up? If so, please hold down the control lock button for 3 seconds and it should allow you to operate the front panel. If not you could be experiencing a problem within your control panel and may need to have a professional come out to diagnose it. I hope this helps. -Matt
Sep 10, 2014 | Electrolux EI23BC56IS (226 cu ft) Bottom...
The letters OP appearing on the control panel of my electrolux refrigerator, what is wrong?
Either the freezer sensor is open in freezer display -or- the fresh food sensor is open in refrigerator display.
The repair is to check wiring between thermistor and board. If the wiring is OK, then replace the defective thermistor (temperature sensor).
Apr 22, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The panel for the ice machine and water dispenser has shut off.
I have had the same probelm for over a year. It appears to be a problem in the touch pad w/ribbon connector which Electrolux refuse to accept responsibility for a faulty product. Model E230575DSS8
Apr 20, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Electrolux Fridge 2 Door, Electronic Panel Problem
there s three plastic boxes the size of three inches long and two inches high there,s a leak there
Apr 04, 2009 | Electrolux Refrigerators
Fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Jun 23, 2008 | Electrolux ERN2820 Bottom Freezer...
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
90 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
