Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet F 06 Error
Whirlpool F 06 is giving F 06 error message. All electrical connections seem to be tight, no issues there. Is this something I can fix myself? I'd sure like to give it a try.
There is a tech sheet inside the machine behind the front lower accesss panel that explains the fault codes. I unpluged the wire harness to the motor and MCU (motor control unit) to inspect them, plugged it back in and it worked OK. Let me know how it works out for you. Thanks..
Posted on Feb 20, 2008
  • comancheejoe Mar 03, 2008
    F 06 came back after 3 loads, I replaced the MCU and have not had a problem, that was last week
Remember that you don't want to do anything that would jepardize your manufactures warranty on parts and labor.
Posted on Nov 09, 2007
WHIRLPOOL DUET WASHER MODEL #WFW9600TW01 F-35 & F-28 ERROR
The F35 indicates a water level pressure sensor failure. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. I hope this helps.
also for the F-28 issue
http://fixitnow.com/wp/2011/06/30/how-to-troubleshoot-an-f28-error-code-in-a-whirlpool-duet-sport-washer/
Oct 28, 2014 | Washing Machines
Whirlpool duet front load washer with F 06 error message
could be control board, in the past this has been an expensive error code to diagnose
Oct 29, 2013 | Whirlpool GHW9150 Duet Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer f-06 error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Whirlpool duet washer shows error message "F 06"
Jan 29, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F 11 error code on Whirlpool Duet - Serial Communication Error ?
Your F11 Code is stateing these things but if it is intermittent probabbly a loose connection.
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Jan 20, 2009 | Whirlpool GHW9300 Duet Washer
Duet GHW9160PW0 F11 Issue
not related to shake, issue, but hte f111 and dl issue def sounds as if the connection between the 2 has been compromisdd, in my experience it has been a faulty CCU, losing communitcationsd with the door latch thus the f11
Dec 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
Nov 08, 2008 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
262 people viewed this question
Dan Webster
Dan Webster
Sal De
