Question about Mtd Yard Machines 158cc Briggs and Stratton Gas Powered Side Discharge Mulch Lawn Mower Red ()
How do I change the fuel tank on my 500 series mtd lawn mower?
    Champion:
  • 279 Answers
Contact MTD if your manual doesn't cover this, or buy a shop manual.
Posted on Dec 22, 2014
buffalonyman
  • 1865 Answers
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
Posted on Jun 12, 2009
mowerman1857
  • 389 Answers
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
Posted on Sep 14, 2009
Dolfoff
  • 148 Answers
SOURCE: how to remove and replace rear wheel tire on my
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
  • 61 Answers
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
Posted on May 09, 2010
SOURCE: i have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Posted on May 14, 2010
Briggs & stratton engine 500 series 158cc + spark plug gap
Look up your engine on the Briggs&Stratton website.They have all the specs. Or call MTD.
May 18, 2014 | Mtd 22" Yard Machine Push Mower
Yard machines by mtd 11b-509n062 lawn mower is leaking gas from what appears to be a fuel line. The fuel line is a few inches below the gas cap.
Not sure what the question is. If the fuel line is leaking it is because it is not on the bottom of the tank well or it has a crack and needs to be replaced
Aug 10, 2013 | Mtd 22" Yard Machine Push Mower
How do I change the fuel filter on a yard Machine 6 Hp mower
A lot of the smaller machines do not have fuel filters, unless you put one in line yourself. Some will have a small screen in side to fuel tank or if you separate the tank from carb you might find a filter, most likely your machine is not equipped with a filter. Good Luck...
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
I clean carberator,and fuel tank also changed spark plug still stats then dies on me why
IF U HAVE ALREADY CLEANED THE FUEL SYSTEM THEN CHECK THE FUEL TANK CAP FOR PROPER VENTING, YOUR ENGINE MAY BE VACCUUM LOCKING.....HOPE THIS HELPS
Nov 24, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Recoil will not pull. The walk behind MTD,Yard Machine mower, a B&S 500 Series stalled while mowing. I went to restart and pull cord will not pull more then a few inches. How do I go about the fix?
If all the safety gear is working on the mower; Possibly sounds like you let it run low on oil and the engine is locked up.
Which would mean a new mower.
Sep 29, 2009 | Mtd Garden
I have an MTD 3.5 hp Tecumseh lawn mower. The
Sep 17, 2009 | Mtd 22" Yard Machine Push Mower
Mtd Yard Machines 158cc Briggs and Stratton Gas Powered Side Discharge Mulch Lawn Mower  Red () Logo
63 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
