Question about eMachines Computers & Internet
Can I upgrade power supply in machine et1831?
4 Suggested Answers
  • 4044 Answers
SOURCE: I have a ET1831 and after about 30 minutes the
It could be a Power Supply issue or Hot chip condition on the motherboard due to lack of Air Flow for cooling or a problem with the motherboard. The first things I would check for are a Virus and Air Flow. There are a couple of Viruses out there that will do this. Get a can of compressed air and open the case and clear all the air channels and blow the dust out of it. With the case open turn the computer on and make sure the Cooling fan on the CPU works and the fan in the Power supply is working. If the CPU fan is not working replace it. Same with the the power supply fan, you would have to replace the complete power supply if that one is faulty. If your Video card has a fan on it make sure that is working as well. You maybe able to replace that fan if it's not but you may have to replace the video card if it isn't working. That would present you with a situation that the Video shuts down but the rest of the computer stays running. You will also want to check your power saver options and make sure you don't have them set to shut the computer down on time. I use screen savers and Hibernate settings to protect the screen from burn in but rarely actually shut down my computers.
Posted on Aug 07, 2010
joelwilcox
  • 1274 Answers
SOURCE: what is the max. power supply I can use on the emachine dodel et1831 05
as far as MAX it doesn't really matter as long as it fits in the case. minimum you need 250w.
Posted on Jul 03, 2012
lars_olsson6
  • 3400 Answers
SOURCE: emachines et1831-07 shuts down mid boot
http://pcsupport.about.com/od/findbysymptom/ht/pconthenoff.htm
find you this to read it stands much to use.
Posted on Jul 10, 2013
Testimonial: "Thank you so much you saved my computers life I figured out that it was the power switch that shorted out."
Power supply for a Et1831-03
many psu s will fit.
they are a standard size (ATX) but you should always measure up just in case - to the nearest couple of mm will be more than adequate, just watch the length.
You need to have at least the power available to you of your present psu more will not do any harm (cept to tour pocket)
Check the type and number of connectors is adequate, and the voltage(mains) input matches your local supply.
It is often said that you should by a good brand (you will pay more), not an unlabelled one.
18.December.2014
Jun 02, 2014 | eMachines E Machines Et1831-07
Need a dual layer dvd burner for desktop emachines ET1831-03
What is special about this machine or its DVD drive?
Check the power supply and data connectors. That is probably all you need to know. Check Newegg.com
e.g.
Home Computer Hardware CD DVD Blu Ray Burners Media CD DVD Burners...
or
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007589%20600003509%20600003655&IsNodeId=1&srchInDesc=dual-layer&name=12X&ActiveSearchResult=True
The DVD+R DL designation is possibly what you want.
Jan 18, 2014 | eMachines ehines et1831-03 pentium...
What is the max. power supply I can use on the emachine dodel et1831 05
Jul 02, 2012 | E-Machines eMachines Desktop PC
My et1831-05 will not turn on when I push power button
First make sure is properly plugged to the wall outlet, then if is plugged properly and doesn't turn on, then probably there is a problem with the power supply for your computer motherboard, nothing to do buy a new one. :-S
This is what you have to buy!
Jan 12, 2012 | E-Machines eMachines Desktop PC
Power supply
Choosing a good power supply depends on a few factors; The amount of power your PC and all it's internal/external connected devices need. The way your PC-casing is built (for airflow).
First it's important to know if you have added any internal/external hardware to the pc since you bought it (hard drives, video cards, usb devices, memory etc.). If this is the case then you definitely need to upgrade, but reading the second and third factors I mention below will shed more light on that.
Second (if possible) you need to check the voltage levels on your current Power Supply via you PC's BIOS or by using a program like Speedfan. If any of the voltages show a reading below what they are supposed to deliver, it means you need a higher amperage on your next Power Supply for that particular line. There are three lines to check (12+, 3.3+ and Core voltage). Usually Power Supplies have a Table with voltages on their sides and on the package. Refer to the one of current Power Supply to see how much amperage your new Power Supply needs to have.
Third it's important your new Power Supply has the fans positioned in the right spots. If your always make sure the air is blowing out of the casing. If it has a small fan on the back, it most likely blows outwards (sucking air from inside your PC case though the Power Supply). If it has a big fan on the top side, it's most likely designed to blow out of the top of the PC case. If it has a fan on the bottom side, it's most likely designed to **** air from the inside the PC casing and blow it through the Power Supply. However it may also be designed to blow out the side of smaller PC casings, in which case the Power Supply is position in front of the motherboard.
Fourth is kind of the-rule-of-the-thumb, always (if possible) buy a brand Power Supply. Generic/Standard Power Supplies do not nearly achieve as much power/lifetime/quality as a brand Power Supply. I recommend a Cooler Master, for their silent but powerful coolers.
Fifth but definitely not a lesser one. Check what connections your PC need. Count the amount of pins connected to your motherboard (usually either 20 or 20+4 pins). Most modern Power Supplies cover most of the connection types. But you don't want to come home with a new Power Supply that isn't going to support your old IDE drives or something.
You could help us help you by providing us with a list of Hardware your computer contains. I can search your PC type and read the specifications, but they don't show what you put extra in/on your machine.
May 13, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I am about to buy a graphics card and I want to know if I have the power to support it. I have an emachines et1831-05
Check your power supply if it at least 300 watts you should be OK. But some need like 500 watts, so.. Also try and get a card that's not too hard on the system, look for a low Current draw device. & check if you can upgrade your Power Supply
Feb 06, 2010 | Computers & Internet
Hi There, I have a new emachines computer and the power supply is only 250 Watts. The model number is ET1831-03. Is the power supply proprietary, or can I use any power supply? It has a PCI Express slot....
use this system unit with LCD or LED monitors ( requiring very less energy or power ) and don't use other peripherals like printers,scanners or other at the time of running the system.
Now , continue with your job. Bi....
Nov 29, 2009 | E-Machines T6528 PC Desktop
Upgrade for Bestec ATX 300 12E
Hipro- HP-P3527F3W
is the replacement for Bestec 300W
Dec 11, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Computers & Internet Logo
20 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
