Question about Hotpoint-Ariston HUZ1211 Upright Freezer
Red light stays on my ariston upright freezer
Why does the red alarm light stay on
Red alarm light flashing
Good Morning Friend, thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. - Z
Jul 18, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to reset the alarm on freezer
Hello Friend, this is Z. Thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards!
Jul 14, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Dec 07, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Door ajar light lit with door closed
Good Afternoon Don, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Oct 12, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door left open for about 90 mins on freezer now red alarm light is on all the time?
Good Morning Martin, thank you for your post!
Oct 04, 2013 | Frigidaire FVE145FF Upright Freezer
Ridare freezer alarm goes off and it wont freeze ice c ream
Hello grega1959 - If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit. This can be done by either by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the freezer. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the temperature control, control board, or a wiring harness. If this is the case, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Apr 14, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Red light stays on
Hi - Did the unit previously experience a power loss? If the temperature of the food rises to a level unsafe for a long-term storage, the buzzer will sound and the red light, if equipped, will also glow. After deactivating the alarm and the unit has run approximately 4 hours, the red light should go off. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn unit back on. If the red light continues to stay on, I would contact a professional to move forward accurately. The freezer may possibly have a communication problem with the control board, temperature control or a wiring harness.
Oct 12, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Hotpoint-Ariston HUZ1211 Upright Freezer Logo
80 people viewed this question
Top Hotpoint-Ariston Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Hotpoint-Ariston Freezer Expert? Answer questions, earn points and help others
