Question about HP Compaq Presario V6000T Notebook
Computer is plugged into wall charger but will not turn on.
  • 390 Answers
Hi
diconnect the power cable from the CPU and connect it to the monitor if the LEDs on the monitor light up if yes the power cable is working else the power cable needs replacement
now connect the power cable to the CPU and have a look to see behind the CPU to see if the main fan is rotating....if yes then the SMPS (power supply unit) is working fine
check to see if the power switch and/or the Reset button on the CPU cabinet is anyway stuck if stuck then a slight tap on the side of the cabinet may solve the problem
if still doesn't work then the electricity is reaching the motherboard and the problem is a lil more internal and you would need some professional help
hope it helped
cheers
Posted on Jun 24, 2009
My nabi can only go on with it being charger thru computer and not using its own charger.
The wall charger is faulty! Do you see any indication on the Nabi that it is charging when the wall charger is plugged in?
Jan 06, 2015 | FUHU 7" Tablet PC NABI2NV7A
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
My tablet will not turn on
If it will not turn on manually, plug it into the computer to see if you have communication. If it can be charge from the USB port in the Computer, let it sit 24 hours for a full charge. In some case wall chargers fail, so try another charger. If you cannot charge from the Computer ort a Wall charger, then the power cell (Battery may be at fault). Replace if you can.
Dec 25, 2013 | Cars & Trucks
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
My camera is a vivitar pink (MID0050609) and it wont turn on, unless i plug it it to my charger and when i do the light on the left is red and it just blinks then flash a blue screen turns on that says...
MSDC is not a problem code. It is normal, the camera is informing you that it's connected to a computer. At this point you should see a new "drive" show up in my computer to transfer pictures.
Have you tried turning the camera on when plugged into a wall charger? If it turns on using the wall charger it might need a charge over night. If the camera will still not turn on after a charge the battery is dead and needs to be replaced.
Mar 12, 2011 | Cameras
My sansa clip will not turn on. i plug into my computer and that will not turn it on either.
try plugging it into a wall based charger and as you plug it into the wall hit the reset button at the same time this should turn it on.
Apr 17, 2010 | SanDisk Sansa Clip MP3 Player
Ipod ''dead''
Plug your iPod into a wall charger, let it lie for a couple of hours. When these batteries become completely flat, it won't easily charge through computer usb, so try the wall charger, see if it works.
Nov 17, 2009 | Apple iPod 4th Generation MP3 Player
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
HP Compaq Presario V6000T Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
