Question about Refrigerators
Maytag mf i 2568 aes fridge panel blinking - Refrigerators
4 Suggested Answers
SOURCE: CONTROL PANEL REMOVAL
noavatar_s.png Navycpowif
Rank:nonexpert_s.gif Apprentice
Rating: 100%, 1 votes
This is NavyCPOwif- As you read above I have a crazy Maytag H20 as well!
I am a research person so looked around a little last night and found a site. for DIY folks. Every one is halving the same problem. I suggest a civil action suit !!! But in the mean time I am going to have my Navy Avionics Technition husband tackle it rather then deal with Maytag right now. " cost almost as much as a military fighter jet, so he should be able to do it!" BUt I wanted to pass this information along to other DIY folks out there. We have not done it yet since ours just went crazy Friday night. So we disconected the door /water connection. But everything else seems to be working fine at this point. Serious about the class action suite!!! these should be recalled we bought ours in GA June 2006 so it seems that the ones made in the 2006 time frame are the ones with the issues- I assuem that the folks that are having problems with in the 7 8 month time frame have the same lot due to ours is 18 months old but we paid $2600 were some have paid $1500.00. So not sure but something needs to be done becouse the list of other issues with this fridge seems pretty long and very expensive.... Good luck!
Site to fix panel issue: for $3 to $20- DIY:
I have just fix my maytag M#MFI2568AEB at a cost of $3.00 Believe or not. You need to go to website hhttp://68.195.103.87:8083/liny/maytagice2o.htm Everything you need is on the site. (yes gets Maytag off the hook, but gets your fridge going quicker)
DIY site for those interested:
http://forums.partselect.com/refrigerator-freezer-repair/maytag-ice2o-digital-board-going-crazy-3189.html
Comment by Navycpowif, posted on Jan 17, 2008 We fixed our ourself with the information I posted above- cost was $5. no problems.... no new panel just 2 circuits.
Posted on Jan 24, 2008
SOURCE: Maytag Ice2O
I had the same problem 4/28/08 - Called Maytag they're sending the part and repairman free.
IN THE MEAN TIME.......Maytag suggested to me to: take a phillips head screw driver and remove the hinge cover from the top of the left door. You'll find a white connector with four wires coming from each side. Disconnect the connector in the middle and the flap will stop (and so will the lights).
Posted on Apr 30, 2008
  • 1891 Answers
SOURCE: Maytag Bottom Freezer Fridge 25 cubic
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Posted on Apr 04, 2010
How do I clean the coils on my Maytag freezer-on-bottom fridge? (Model #i is MF D 2560HEW)
HI,
Pick up a coil brush from you home improvement center near you and remove the grill in the front under the freezer door. With the brush, brush the coils under the unit to clean them. Have a vacuum handy, you will need it for dust and hair if you have pets in the home. Good Luck
Apr 20, 2016 | Maytag Refrigerators
Maytag panel flashing and flapper keeps popping
The same thing happened to my frig, also a french door model. I am told this is a known problem on my model MF 12568AES. I called Maytag on their 800 number, mentioned I knew this was a problem they knew about. They denied any knowledge of it, so I told them it was the high voltage board, the (2) 35w 680uf capacitors and they had a technician at my house within 2 days and although they didn't make that same board any more, they sent mine in for repairs. Over 30 days later it was re-installed and it works great. There was no charge for the service calls. My fridge is 8 years old. You can also read info from http://applianceguru.com/forum1/13035-1.html#ixzz2ghTCinxG. In there is a temporary fix until the board is repaired or replaced.
Apr 09, 2014 | LG LRFD21855 Stainless Steel French Door...
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Ae display warning
Hi
Error AE means that the machine has detected a leak in the base of the washer. The anti flood device has detected the water and its displaying the error AE.
Unplug the washer and remove the back panel of the washer. Check for any stagnant water present in the base of the washer. If no water is present then check for the anti flood sensor and any disconnected wires.
Please post back for any further assistance.
Daniel
Jul 26, 2010 | LG WM-12120BD Front Load All-in-One Washer...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
The ice trap door won't stop cycling open and closed and the control panel on the door is blinking all of the lights
Called maytag with model and serial number. This is a very common problem. They sent a new mother board free of charge within a couple of days. You will have to go to the back of the fridge to swap mother boards. It was pretty simple if you have a little patience. Maytag wanted to charge $200 for the service call but it took my husband about twenty minutes. Then you will need to reprogram with the code inside of the door. I was told that this happens alot if there is a power surge, so I now have the fridge on a surge protector. Haven't had a problem since. Hope this helps.
Nov 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Blinking board and flaping ice door
I had the exact same problem. Maytag sent me a new main board which fixed the problem. It is pretty easy to install and is located behind the fridge behind a metal panel.
Mar 23, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Jan 24, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
