Question about Amana AFB2534DE Bottom Freezer French Door Refrigerator
Maytag fridge panel blinking - Amana AFB2534DE Bottom Freezer French Door Refrigerator
How do I reset or reboot my maytag fridge. I already replaced the control panel. MFI2568AES
SOME FRIDGES HAVE A RESET BUTTON IN THE CONTROL BOARD OR ON THE CONTROL BOARD
Apr 01, 2015 | Maytag Refrigerators
I put a new filter how do I reset
I have done some research and here are some steps to solve the problem: For Maytag and Jenn-Air refrigerators press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks. Once it blinks release the buttons and the reminder light should be reset.
http://www.freshwatersystems.com/s-372-maytag-refrigerator-filter.aspx
Jun 01, 2013 | Maytag MZD2766GES Side by Side...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
The ice trap door won't stop cycling open and closed and the control panel on the door is blinking all of the lights
Called maytag with model and serial number. This is a very common problem. They sent a new mother board free of charge within a couple of days. You will have to go to the back of the fridge to swap mother boards. It was pretty simple if you have a little patience. Maytag wanted to charge $200 for the service call but it took my husband about twenty minutes. Then you will need to reprogram with the code inside of the door. I was told that this happens alot if there is a power surge, so I now have the fridge on a surge protector. Haven't had a problem since. Hope this helps.
Nov 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Fridge MTB2156GEW Won't cool. Change thermostat today and ran it for four hours. Frige was warm after. There is a clicking noise every 2 to 5 minutes from the back of the fridge. I think it is
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
May 20, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
I need to know where the adaptive control defrost board is located in the fridge
In the top right rear corner of the control panel.
What is your problem?
BTW your fridge is on recall from Maytag.
Apr 13, 2009 | Maytag MZD2766GES Side by Side...
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Blinking board and flaping ice door
I had the exact same problem. Maytag sent me a new main board which fixed the problem. It is pretty easy to install and is located behind the fridge behind a metal panel.
Mar 23, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Amana AFB2534DE Bottom Freezer French Door Refrigerator Logo
27 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
