Question about Nikon Coolpix S4000 Digital Camera
Nikon coolpix s4000 camera shows lens error when lens goes out , then lens goes back in. what is wrong?
Rammsteins
  • 300 Answers
SOURCE: my 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Posted on Jul 31, 2009
  • 11967 Answers
SOURCE: Nikon coolpix s202 shows lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 28, 2010
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Posted on Mar 29, 2010
  • 11967 Answers
SOURCE: camera's lens is stuck
Posted on Apr 23, 2010
tbreeze47
  • 3083 Answers
SOURCE: My nikon coolpix camera says lens error and beeps
Here's a web blog about what you can try to do to fix the problem. They say about half the cameras can be fixed by trying their suggestions. Here it is:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Also, before having it fixed, get an estimate. Sometimes it's just better to go ahead and buy a new camera, since the cost of repair can be high. Good luck, and hope this helps.
Posted on Jul 23, 2010
On my Nikon Coolpix S4000, when power is turned on, the lens extends fully, opens, retracts fully, and then closes automatically. Lens Error then appears. It does not make noises and has not been used...
I had the same problem with a similar Coolpix model. It's an error on the lens mechanism. Maybe you pressed the lens by accident while they were retracting, or something like that... It's really a delicate mechanism. I think you have to send it for a service... Sorry!
Mar 15, 2014 | Nikon Coolpix S4000 Digital Camera
When I'm taking a picture, and i try to zoom, it zooms a little then stops, says lens error and goes black. If i turn it back on, it goes on, I just can't zoom.
Most digital cameras jams are the cost of lens problems while zooming, with Nikon Coolpix S4000, simply use your fingers carefully pulling on the lens while turning the camera on. this can be done by getting your fingernail under the lens opening and gently pull.muunlyte5608.jpg
May 10, 2011 | Nikon Coolpix S4000 Digital Camera
My battery has went dead and when I went to charge it. It wouldnt charge at all. Plus, when it was working and I would go to take pictures, it would sound as if something was loose in the lens.
If your Nikon EN-EL10 battery for your Coolpix S4000 won't be charged, there seems something wrong with your battery or battery charger, so you need a new one. The problem about lens, if something was loose, there maybe a screw and after a term it may cause lens error.
Feb 08, 2011 | Nikon Coolpix S4000 Digital Camera
My nikon coolpix camera says lens error and beeps when i turn it on and then goes back in and shuts off.. What can i try to do to fix before shipping it off to nikon?
Jul 04, 2010 | Nikon Coolpix S4000 Digital Camera
Nikon Coolpix S202 "lens error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2009 | Nikon Coolpix S210 Digital Camera
LENS ERROR
My Nikon L14 Camera Is Showing Up Lens Error
Can Someone Please Help Me.
Aug 22, 2008 | Nikon Coolpix L14 Digital Camera
Nikon Coolpix S4000 Digital Camera Logo
133 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
