Question about Facebook Apps
Why wont sync - Facebook Apps
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
New computer wont sync ipod
Your ipod is synced with your other cpu
an ipod can only be synced with one cpu at a time
you need to change the setting to sync with this cpu
http://www.apple.com/itunes/how-to/#video-sync
Apr 06, 2010 | Apple iPod nano
Wont sync
You cant sync with another PC even if u sync all the data erases... because all the data which u have on your ipod relates to your PC itunes.
Jul 20, 2009 | Apple iPod nano
Controllers wont sync
If you have pressed the sync button on wii, then on the wii-mote, and it still didn't sync, try unplugging the Wii console for few minutes and try the process again.
There is another syncing mode, but you have to have at least one wii-mote connected to the wii. You press the home button and the click on the wii-mote on the screen. There will be a reconnect button. Press that and then press both the 1 and 2 buttons on the wii-mote[s] you want to connect. This is the ONE TIME ONLY connect mode, used when playin on a friends Wii. Once the Wii is powered off, the wii-mote wont be connected any longer and will still be the default wii-mote for your wii system [not on your friends]. Hope this helps.
May 10, 2009 | Nintendo Wii Console
Xbox wont sync with my wireless contorller
Have you ever synced one of these controllers before?
Hold the controller in your hand as if you were playing a game. Next flip the controller up so that the buttons on it, are facing you.
There is a small white button that you will see. Power your xbox up and after you get to your main menu press the sync button located about 2 inches to the left of your main power button on your console.
Press the described button on the console and then the described button on your controller. The two should sync together perfectly fine.
May 03, 2009 | Microsoft Xbox 360 Wireless Controller
Ipod wont sync
hello.
i am so sorry to tell you that the HDD(hard disk) is defective.
you shud replace that part.
Apr 26, 2009 | Apple iPod MA446LL/A MP3 Player
I CANT GET TV SHOWS ON MY IPOD!
if its set to sync only checked songs and videos then make sure in tv show tab that its checked to sync and in itunes section tv shows that the show is selected
please rate well
Jan 06, 2009 | Apple iPod touch
I touch wont sync properly
Try just clicking and dragging the playlist onto the ipod which will get the songs on there for you. When you do sync, I do not think it transfers playlist automatically. You have to do it yourself.
Jan 04, 2009 | Apple iPod touch
Ilo wont sync
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 26, 2008 | iLO (2 GB) MP3 Player
Facebook Apps Logo
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Facebook App Expert? Answer questions, earn points and help others
