Question about Cub Cadet Garden
Koeler cv460s head cylinder torque - Cub Cadet Garden
c17hydro
  • 2984 Answers
SOURCE: cylinder head torque settings 1990 2.6L isuzu motor
From front to back is this:
7 3 1 5 9
8 4 2 6 10
First torque value is 58 ft lbs.....then final torgue is 72 ft lbs.
Posted on Mar 21, 2009
  • 462 Answers
SOURCE: what torque spec for chev aveo 2004 cylinder head
18 lb ft+60°+60°+60°+10°
NEW HEAD BOLTS ARE REQUIRED WHEN REPLACING THE HEAD OR HEAD GASKET.
Posted on Jul 04, 2009
  • 88 Answers
SOURCE: Hi I'm looking for cylinder head torque settings for a 1992 BMW 316/318 e36
BMW cylinder torque setting all models
According to my service manual as follows.
Cyl head to engine block (torx e12 M10 bolts)
Stage 1 30nm (22 ft – lb)
Stage 2 + 90 degrees
Stage 3 + 90 degrees
Cyl head to lower timing chain cover 10nm (89in – lb)
The tightening sequence is from inside to outside crossover as normal. Loosening sequence is from outside to inside crossover. Remember to set torque wrench at low setting and work gradually up through the whole sequence until you get the desired torque.
Posted on Aug 29, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
  • 122 Answers
SOURCE: need cylinder head gasket torque specs.
looks like there is special sequence to reassemble and tightening, a quick note replace any bolts that have two punch marks.tighten as follows: x x x x x 10 4 2 6 8 x x x x x 7 5 1 3 9 torque all down to 15 ft lbs torque to 30 ft lbs plus 90 degrees. Good luck!
Posted on Sep 18, 2009
Torque specification
Apply a light coat of engine oil on the threads and
under the heads of the cylinder head bolts.
- Install the plate washer to each cylinder head
bolt.
- Using Torque wrench, install and uniformly tighten the ten
cylinder head bolts in several passes.
Torque: 60 N-m (610 kgf-cm, 44 ft-lbf)
Jan 26, 2014 | 1993 Toyota Corolla
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Correct pressure for torque the head of mazda pickup 1998
Since you didn't say which engine you have, I've pulled torque specs for 3 different engines. Also, since I can't include a diagram showing the relative locations of the numbered head-bolt locations, it would be a good idea for you to purchase a vehicle specific repair guide that will show this info.
Take particular note about the TTY (Torque to Yield) bolts used on 2 of the 3 engines shown. It is said that new head bolts MUST BE USED when head is replaced or re-installed to obtain the proper torque.
B2500 4 Cylinder
Torque sequence: --------- ' 10 6 2 4 8 ' front ' ' ' 7 3 1 5 9 ' -----------Step 1: torque in sequence to 51 Ft/Lbs Step 2: torque again in sequence to 51 Ft/Lbs Step 3: final tighten all bolts an additional 90 to 100 degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
B3000 3.0 6 Cylinder
Torque sequence ---------- ' 6 4 2 8 ' ' ' ' 5 1 3 7 ' ---------- Step 1: torque to 59 Ft/Lbs Step 2: loosen in sequence (1) full turn Step 3: torque to 41 Ft/Lbs Step 4: torque to 73 Ft/Lbs
B4000 4.0 6 Cylinder
Torque sequence --------- ' 5 1 3 7 ' ' ' ' 6 4 2 8 ' --------- Step 1: torque cylinder head bolts in sequence to 26 Ft/Lbs Step 2: torque cylinder head bolts to 56 Ft/Lbs Step 3: turn cylinder head bolts in sequence an additional 90-degrees recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) that permanently stretch during the initial installation. New head bolts must be used when cylinder head is replaced or re-installed to obtain proper torque.
Good luck with this job!
Feb 06, 2011 | 1998 Mazda Pickup
Looking for head bolt troque spec for 3.4l impala sfi04
Please don't forget to rate. Thank you:
Left side front cylinder head
Cylinder head bolt torque sequence-3.4L engine
  • Cylinder head by aligning it with the dowel pins
  • New cylinder head bolts coated with a sealant (such as GM 1052080). Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm). Using a torque angle meter turn the bolts 90 degrees in the proper sequence.
  • Left side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plugs. Torque the plugs 11 ft. lbs. (15 Nm).
  • Right side rear cylinder head:
  • New cylinder head gasket
  • Cylinder head on top of the gasket and make certain it is lined up properly with the dowel pins
  • Right side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plug wires
  • Exhaust crossover pipe. Torque the fastener to 18 ft. lbs. (25 Nm).
  • Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10 Nm). Using a torque angle meter torque the fastener an additional 30 degrees.
  • Lower intake manifold. Torque the bolts to 115 inch lbs. (13 Nm).
  • Upper intake manifold. Torque the bolts to 18 ft. lbs. (25 Nm).
  • Nov 26, 2010 | 2004 Chevrolet Impala
    I need to find the torque specs for the connecting piston rod? also the sequence and torque for the cylinder head bolts this is for a kia rio 2004 6cyl
    22 - 24 ft. lbs. for the rod caps and....
    110795143Cylinder Head Tightening Torque and Sequence.
    Tighten cylinder head bolts in order shown.
    Tightening torque: 36.1 ft. lbs. (49 Nm, 5 kg-m)
    Loosen bolts in reverse of order shown.
    Retighten cylinder head bolts in order shown.
    Tightening torque: 18 ft. lbs. (25 Nm, 2.5 kg-m)
    Mark cylinder head bolts for rotational reference.
    Rotate cylinder head bolts 90°(1/4 Turn) in order shown.
    CAUTION:
    • Do not reuse the old cylinder head bolts.
    May 31, 2010 | 2004 Kia Rio
    Head gasket torque specifications and sequense
    Cylinder head bolt torque sequence—3.4L engine
  • Spark plug wires
  • Mar 06, 2010 | 2001 Chevrolet Venture
    Cylinder head bolt torque chevrolet 3.4
    here is the troque spec for the cylinder heads.
    Cylinder Head Bolt
    • First Pass
    60 N·m
    44 lb ft
    • Final Pass
    95 degrees
    Cylinder Head Bolt
    • First Pass
    60 N·m
    44 lb ft
    • Final Pass
    95 degrees
    Cylinder Head Bolt
    • First Pass
    60 N·m
    44 lb ft
    • Final Pass
    95 degrees
    first pass 44 ftlbs
    second pass 95 degrees
    Jan 30, 2010 | 2003 Chevrolet Impala
    Torque setting cylinder head bolt 4 cylinder KIA sportage
    I need the torque settings and pattern for a Kia Sportage 2.2
    Nov 24, 2009 | 2001 Kia Sportage
    Need to know cylinder head bolt torque specs
    Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
    Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
    Garden Logo
    Top Cub Cadet Garden Experts
    Tim Whalen
    Matt Olenzek
    Matt Olenzek
    roeb
    Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
