Question about Vivitek V37655 56" DLP TV
After a while the screen flickers and then shuts off and won't restart. Especially in hot weather
    Problem Solver:
  • 5 Answers
Thomas,
I am not sure if this is what I experienced, but it won't hurt to take a look at what I did.
I had a similar problem.
My TV started to flicker and I put a new bulb in. The new bulb did not help, even if it is good to replace after a couple thousand hours.
I found out that my heat sink, which is sitting on the CPU with the mirrors came loose and the unit overheated and shut off after flickering a while.
Try to take the lower back panel off and you see a heat sink which is sitting in the center of a aluminum sheet metal piece. Disconnect the wires which are attached to the circuit board behind the sheet metal. Then take off the screws holding the sheet metal and pull it gently off. It will take a little force, but it does not damage anything. Now you see the heat sink on the circuit board held by a latch going across the heat sink.
On the upper right corner you will find the handle to open the latch. Once you did it , you can take the heat sink off and see the main CPU (as I took the latch off, my heat sink fell off).
On my heat sink the Heat Sink Compound Paste creating the connection between the CPU and the heat sink dried out and became brittle, son there was no connection anymore and the heat couldn’t be transported out through the heat sink, which is cooled by a fan on the left.
I took the brittle Heat Sink Compound Paste off and applied a generous portion of the one that I bought at Radio Shack. I used a Silicone-Base Heat Sink Compound which ran $4.99 excl. tax.
After applying the paste put the heat sink gently in and when you do, you will feel like a suction indicating that you have a connection between the CPU and the heat sink.
Now you need to put all parts back together.
If you are not familiar with electronics and those wires or wouldn’t hurt or would be wise to mark the connectors and to make pictures before removing them. This will save you a lot of frustration.
I hope this helps you and brings your TV back to life. My TV was cutting out after 25 minutes and runs now like a charm.
Good luck.
PS: If you experience a black screen with vertical stripes (mine were white and green) then most likely the light engine needs to be replaced, I had this after 9 months and got it fixed under warranty
Posted on Jul 04, 2009
  • tcsmooth Aug 28, 2011
    Cannot find heat sink unit. Dismantled television PLEASE HELP!!!!!!!!!
2001 CL K4 30 has anybody had problems with the car shutting down while driving especially in hot weather Mercedes dealership told me I need a new gas tank
the dealer should have read the codes first to find out if you have a venting problem
engine shut downs in hot weather should show a code
suggest that you visit an accredited workshop that deals with MBs as they may have more knowledge than the dealer.
remember --any problems regardless--always read the fault codes first
Jul 01, 2015 | Cars & Trucks
Car shut off while driving and won't restart, gauges flicker
If it is a 2006 then you probably need a new battery, which is located under the hood of the car. If the gauges flicker, the battery is probably too dead to start the whole car, but it will still try to start it. Hoped it helped.
Feb 25, 2013 | 2006 Mazda Tribute
My truck stalls and dies in hot weather and won't
not too familiar with the rangers of that era, but if it has a computer the n its probably bad. my 2001 firebird had the same issue.
Jul 30, 2011 | 1986 Ford Ranger 2WD
Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Feb 25, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Vapor lock and starting problems
Never heard of that on a buick FI. When it gets hot does it cut off and restart later? More info.
Aug 17, 2009 | 2002 Buick Rendezvous
Engine cooling fan runs after key is removed from ignition
This is normal. It may run for a few minutes especially in hot weather.
Jun 18, 2009 | 2002 Chrysler Town & Country
Won't start after being shut off in hot weather
Replaced Fuel Pressure Regulator. So Far SO Good
Aug 04, 2008 | 2002 GMC Yukon XL
Vivitek V37655 56" DLP TV Logo
450 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
