Question about Pinnacle Computers & Internet
Rgb internal wiring compatible with the video cord red white n yellow
Need the configuration of internal wires of a rgb so I can hook it up to red white n yellow plz
    Novelist:
  • 206 Answers
Composite video to a internal video. This of course can only be a output source from computer to a composite display.
Rgb internal wiring compatible with the video cord - 1daced96-6420-4367-97d7-6dcafc6d9cc6.jpg
Hope this helps.. Isn't Fixya awesome..
Posted on Jun 18, 2014
  • Will Godwine Jun 18, 2014
    OH! Easier to buy a conversion box. But yet again, this will only be for video out to a older display or a TV with composite video in.
3 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: hi help plz
You can find the driver at the manufacturer's support site, driverguide.com, or if it's the original video card that came with a brand name machine, at the machine manufacturer's support site.
Posted on Aug 21, 2008
  • 88 Answers
SOURCE: RGB NO OUT PUT VIDEO
Not enough information to assess the problem realistically; it could be the monitor is turned off or disconnected, video card failed, cable is bad, wrong video mode is used, card loose in the socket.
Posted on Apr 04, 2012
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Haeir TV does not have a yellow port. How do I hook up the WII?
Hook your yellow wire from Wii to Red Green or Blue. Typically it's the blue. These are called RGB inputs.
Jun 13, 2016 | Video Game Consoles & Games
I just need to know what wires go from one place to another
(1) Use a HDMI cable for the DVR/Cable source. It has audio and video combined.
(2) Use Optical (laser) Wire if you have a source and corresponding wire.
(3 Use Y (yellow) for video source. R (Red) and (W) White for Audio Left and Right sources from a VCR/DVD.
(4) Use RGB (Red, Green and Blue) from devices that have RGB output like old analog video camera.
(5) You can also use antenna for direct TV signal
Feb 01, 2016 | LG Televison & Video
Rgb internal wires which ones can u use to convert it into red, white and yello at other end for tv
RGB is a term that means the guns in the crt or other display are only driven by amplifiers for that color. So you have to have seperate signals and inputs for red,green and blue. Those come from the source in that method. They are then fed into the monitor for which each of those colors has its own channel and amplifier. If you dont have something that is supplying the RGB singals then it is of no use. The colors that you listed as red white and yellow are for COMPOSITE video with AUDIO. The yellow is the whole video signal and the red and white are stereo sound signals. No attempts at making that work will correct this unless you buy a converter.
May 14, 2014 | Philips 107E66 17" CRT Monitor
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
Which do i plug red yellow and white into
If you are using the RGB (red, green, blue) and the the red, yellow, and white cables. Then the RGB cables are in place of the yellow, you should plug the cables into a Component input on the tv you are using. The red and white cables are the audio cables and should be plugged in but the yellow will not be used if you are using RGB.
If you have only the yellow, red, and white cables, just match them up with an input on the tv or any player that has the inputs.
If you need a new cable, Amazon sells one along with any local store such as Walmart or Best Buy. http://www.amazon.com/PlayStation-3-Component-AV-Cable/dp/B000MIXFWA
Does this help? If you have further questions, please let me know.
Benjamin
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
Need the manual to find out how to setup AV3 & AV4 as Component input, or if it is compatible with standard component input. Does not seem to work
Well, lets start here first. I would like you to look at the input jacks for a/v3 and a/v4 and see if they are color coded RED-GREEN-BLUE. or if they are just YELLOW-RED&WHITE (audio). If they are RGB then just buy RGB cables at your local Best Buy. If any are just Yellow and Red & White then those are just regular composite video the same as the old vcr's. You can't make A/V jacks work like RGB component jacks.
Dec 01, 2010 | Televison & Video
DVI to RCA3 AV OUT
DVI to Composite Video (yellow) adapters are available in many online stores for mail order. You will need to get a separate mini-RCA jack to stereo RCA adapter to hook the audio output from the computer to the stereo audio (red and white) connections of the cable.
Search google for DVI to composite video adapter, and the mini-RCA adapter can be found at most home entertainment or electronics stores (Best Buy, Circuit City, etc)
Jun 10, 2008 | Dell XPS 200 PC Desktop
DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Sep 03, 2007 | Philips Magnavox 27MS343S 27" TV
Computers & Internet Logo
66 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
