Question about Whirlpool DU1300XTVQ Dishwashers : Built in Dishwasher
My Whirlpool Dishwasher DU1300XTV
Pots & Pans LED lights & Dry Heat are flashing Code#1...Did reset & still comes back to Code #1
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Heating element goes bad causing the controller to go bad as well
Posted on Jun 10, 2014
dutchman05
  • 487 Answers
SOURCE: WHIRLPOOL QUIET PARTNER IV
Ok this can mean 2 things.
Pump or filter is clogged
or heater is not working correctly. Can you give the precise model number?
Posted on Aug 18, 2008
  • 423 Answers
SOURCE: The only number on the nameplate of my
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Posted on Mar 31, 2009
BIKER T
  • 909 Answers
SOURCE: I have a Whirlpool Quiet Partner dishwasher that stopped working
that is a typical indication of a faulty board. once replaced, i suggest a surge plug to be installed. it will protect the unit from future power fluctuations.
Posted on Sep 15, 2009
SOURCE: GU2500XTPS3 QUIET PARTNER - NO START.
23310532.jpg The dishwasher will not start. The following things have occurred;
1. The Cycle option light is flashing.
The model is GU2500XTPS3
Can anyone please assist if they have seen this problem before?
Posted on Jul 21, 2010
oldTech2332
  • 2341 Answers
SOURCE: the panel is stuck on pots/pans for cleaning and
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Posted on Sep 06, 2011
RESET DU1345XTVB
Try to turn the mains power off and on. If this makes no difference then try the hard reset by pressing POTS/ PANs and Heated Dry button consequitively for about 10 secs. All lights should turn on. Then cancel and see if there is any difference.
Apr 13, 2014 | Whirlpool 24 in. DU1050SS Built-in...
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Pots and pans and normal lights blinking
That reset sequence code didn't work for me. We tried everything on a ton of forums.
What I did to fix our Whirlpool dishwasher was to disconnect the drainage tube from the garbage disposal. I noticed it smelled really bad so I figured it was clogged. I used a bucket to catch the water left in the tube. I took the sprayer from the sink and flushed out the tube. 4 pumpkin seeds and a couple of beans landed in my bucket. I flushed it a couple times. I hooked the tube back up to the disposal and sure enough all the lights returned to normal. I pressed start and it came on.
Feb 22, 2010 | Whirlpool GU2200XTSB GU2200XTSQ 24 in...
Oct 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Whirlpool DU1300XTVQ Dishwashers : Built in Dishwasher Logo
107 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
