Question about Brother ULT2003D Disney Sewing & Embroidery Machine
Why does my Embroidery machine shut down while I'm embroidering?
While I'm embroidering the machine will turn off then come back on several times within a 10 min period. I have to start it back at beginning and find where it stopped at. HELP!
  • 4 Answers
SOURCE: Using a Brother ULT 2003
The solution is to take it to an authorized Brother dealer. It sounds like either something wrong with your embroidery hoop sensors, or more likely something is wrong with the brain of your sewing machine. Hopefully after all this time you've done just that. I'd hate to think of a ULT just sitting around collecting dust.
Posted on Nov 22, 2008
  • 4 Answers
This is not normal operating behavior for a ULT, take it your a Brother authorized repair center so they can inspect the sensors and the program.
Posted on Nov 23, 2008
SOURCE: Machine not sensing embroidery frame
Depending on your model of machine this problem is solved by replacing the hoop attachment unit on the hooping arm. (hoop sensor cable is not properly welded)
Posted on Jan 14, 2010
  • 980 Answers
SOURCE: SETTING THE TIMING ON DISNEY BROTHER PE-180D EMBROIDERY MACHINE
Email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Mar 07, 2010
Testimonial: "although this was very helpful i decided to take it to a shop and let them sort it out thanks for the help"
  • 1564 Answers
SOURCE: My brother 270D keeps shutting off
Take your machine back to the other side of the house. See if it works better there. If it does have an electrician come out and check the new location's power. There may be a problem in the houses wiring.
Posted on Sep 07, 2012
Singer futura xl-400 should the feed dogs be disengaged when embroidering
ABSOLUTELY! The XL models of embroidery machines are supposed to automatically lower when you put the embroidery unit on, but I have had an XL-400 and currently have an XL-550 and Quintet, and I have noticed on the latter two that the feed dogs have not always automatically lowered. Incidentally, to lower or raise the feed dogs, the lever (it's in the back) goes DOWN and OVER. If you are having problems getting it move, use a straight blade screwdriver and pop the little tip off--it's not necessary to operating the feed dogs.
Also incidentally, when you raise the feed dogs, you have to turn the hand wheel towards (ALWAYS towards you for anything) several times to get the feed dogs to actually pop up. You'll hear when it does that. They lower right away, though.
Jun 11, 2014 | Singer Sewing Machines
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
How do I find out the embroidery time on my Viking Designer 1 sewing machine?
Hi there, If your trying to find out how long it took you to embroider something, You need to go to your touch screen menu- touch Set- then down at the bottom left of this screen and touch More- three (3) times you'll get to where it says Running time:(It's the 3rd Selection) There it will actually show you the total running time (Sewing and Embroidery If you haven't zeroed it out by hitting the zero (0) next to that selection.) You can do this on the touch screen with the embroidery unit on or off. You need to touch the zero (0) to zero out your time before you start an embroidery project. Once you've done this and you've finished an embroidery you can check how long it took by the touch screen menu- Set- touch More 3 times and there you will see how long on the Running time it took to embroider your design. I hope that helped. The total time your machine has ran (Embroidery and Sewing) is kept in Memory on the Service Screen that your Technician gets into when he services your machine. So your not actually wiping out that. The Set menu is just for you to keep track of how long your machine sews or embroiders something pretty much. I hope that helped you out with your question. Happy Sewing!! Kathy
Nov 19, 2010 | Husqvarna Designer I
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
I am trying to embroider something for the first time on my viking #1 husqvarna. Do I need presser foot Q/ or R/ .If it's R,I can't find it-what does it look like? I need someone to walk me thru the steps...
embroider on #1+:
If it's a #1+ I recommend the Q (the spring works better) it's hard to put on, but worth it.
Here we go:
1>Turn off machine (always when installing or removing embroidery unit)
2>Install Q Foot. Always leave presser foot pressure (on left end of machine) at 6 for presser foot Q
3>Insert Embroidery Card
4>Insert Embroidery cassette (matching #’s with card)
5>turn on machine
6>Turn on embroidery unit (on cassette)
7>Select design
7>Thread for color 1
8>press reverse to start the machine embroidering....weeeeeeeee!
Jan 18, 2009 | Husqvarna Viking 1
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Brother ULT2003D Disney Sewing & Embroidery Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
