Question about GLAXOSMTHKLN Aquafresh Direct Toothbrushes 31 Soft 2-Pack - 2 EA
How can I find your Aquafresh Direct 31 soft toothbrush
Tip
How to Get Rid of Scaly Lips
If you suffer from scaly lips, a simple do-it-yourself trick to exfoliate them takes only a finger scoop of Vaseline and a toothbrush. <br />Step 1: Slather lips with petroleum jelly <br />Step 2: Use a toothbrush to massage in the jelly in a circular motion. <br />Step 3: Wipe off the excess petroleum jelly. <br /><br />The toothbrush exfoliates lips while the petroleum jelly leaves lips extra soft. Repeat a couple times a day until your lips are no longer scaly. <br /><br />Want a more professional exofoliator that's perfect for the purse? Try The Lip Scrub by Sara Happ, a sugar scrub created just for the lips. The results are similar to my Vaseline and toothbrush trick, but it frankly tastes so great (I love the peppermint flavor) and leaves lips so soft and supple I think Sara should add a "Warning: May be Addictive" message on her label. Makes a great gift for any discerning friend. <br /><br />Choose from a variety of flavors. Buy it online for $22. <br /><br />
on Nov 22, 2010 | Health & Beauty
Tip
Washing your Cloth-top
Vacuum the top with a brush attachment, then rinse thoroughly with low pressure water to remove loose soil. Spray RaggTopp Cleaner evenly over the entire top and scrub lightly with a soft nylon brush. Then rinse thoroughly with low pressure water until no remaining soap foam is seen. If any difficult soiled areas remain they may now be spot cleaned by applying RaggTopp Cleaner directly, letting it stand for 10 to 20 minutes, scrubbing with a soft toothbrush, and then thoroughly rinsing the entire top again. Do not attempt to remove contaminants by scrapping with any sharp edged tool. When the top is clean dry it with a microfiber towel. After washing the top the car must be washed to prevent spotting or filming. Leave the top up until it is completely dry. This may take an hour in direct sun, or as much as 24 hours in cool, humid weather. After the top has thoroughly dried its water repellency must be renewed
on May 19, 2008 | 2003 BMW Z4
Phone goes to voice mail w/o ringing
Obstructed/bad dock connector
Check the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. High concentration isopropyl alcohol (at least 90%) and a cotton swab should be used to clean any debris that does not come off with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Dirty or corroded logic board connections
After an iPhone has been submerged in a liquid, there may be some corrosion or debris on the logic board connections that cause this error message. Remove the logic board and clean all of the contacts with a soft cotton swab and high concentration isopropyl alcohol (at least 90%).
God bless you
May 24, 2013 | Cell Phones
What accessories do I need in order to brush my teeth?
You need an extra soft bristled manual toothbrush, toothpaste you like which must contain fluoride and a mouth rinse.
Feb 03, 2013 | Health & Beauty
Polar t31 manual, heart monitor \ need manual
Please go to my tips and tricks page, there is a link to download the manual for all polar products.
Here is the direct link to the F11 in english. If you need in another language than follow the link at my tips and tricks page.
The T31 is the chest strap. The F11 comes with the T31-Wearlink (soft strap) the T31 is a hard strap. different user manuals. The manual you want is listed as (wearlink 31 coded transmitter)
Dec 15, 2010 | Polar F11 Heart Rate Monitor
Should I use a dry toothbrush or a swab damp with alcohol to clean cartridges?
Hi:
To clean the contact area or the print head on your ink cartridges, only use water, and a soft cloth or paper towel. A dry toothbrush can be used to gently brush the contacts in the printer, where the ink cartridges mount.
Dec 05, 2009 | HP DeskJet 895cse InkJet Printer
Watch needs cleaning.
Find a good jewelry cleaner where you can soak jewelry (rings, earings) and let only the band soak. Use a soft or medium toothbrush to finish with the band, then dip the toothbrush in the cleaner to clean the rest.
May 11, 2009 | Watches
My Steiner Navigater 7 by 50 were coated in a thick layer of sticky pollen. I briefly rinsed them under the tap and now the right hand side (with the compass) has condensation in it. I thought that because...
If weather cooperates, put them out in the direct, bright sunlight for a couple of hours.I have done this many times in the last 30 years or so.Usually that will drive the moisture out.I generally clean the outside of my binocs with a paint brush, or in some cases, a toothbrush.For the lenses I use a soft cloth.No solvents.Good Luck
Mar 15, 2009 | Steiner Navigator Pro Binocular
GLAXOSMTHKLN Aquafresh Direct Toothbrushes 31 Soft 2-Pack - 2 EA Logo
91 people viewed this question
Top GLAXOSMTHKLN Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a GLAXOSMTHKLN Health and Beauty Expert? Answer questions, earn points and help others
