Where can i purchase spare parts for bauholtz
Need to purchase replacement accelerator trigger assembly
  • 1388 Answers
SOURCE: Stanley Framing Nailer Leaking Air Around Trigger
Your tva11 valve can be repaired easily if you have a source for orings. I purchase orings from several companies including lowes (in plumbing dept sold in 10 pack for about dollar), www.grainger.com (oring kit metric, cost about $10) harbor freight (oring kit about $5), also orings are sold by size at bearing companies. I have repaired many of these valves by just cleaning debris and lubing with silicone paste (sold at lowes in plumbing dept used for lubing faucet orings). To attempt repair of valve, remove nails, remove roll pin that holds trigger (3mm) to expose tva11 valve. Mark position of valve in body of gun because the retaining pins fit thru an indention in the valve. Next remove roll pin/s that hold tva11 valve, they are just above the valve in the body of the gun(3mm x 30mm). You will need to apply air pressure to gun to remove the valve, however use heavy glove to catch valve because it can come out with force. (try lowering air pressure to gun for this procedure. With valve in hand, use marker to mark position of inner part in relation to outer, remove the two pins that hold valve together. Push out the inner cylinder and look at the middle oring(usually the problem, could be loose or cut) , If cut or loose replace and lube with silicone paste and re-assemble. Check outer orings for nicks, replace as necessary (usually good). Clean valve port, lube port, then re-install valve into gun and insert temporary retaining pin and test for leak. You should be good to go. Good luck and email if you have questions.
Posted on Mar 30, 2009
  • 8 Answers
SOURCE: spare parts for spear and jackson strimmer spjbc30
solent tools tel 023 8057 8057
email sales@solent tools.co.uk
Posted on Jun 16, 2009
gokomets
  • 120 Answers
SOURCE: I need to replace the laser assembly on a ADCOM GCD-750
I thought it used a KSS-240 which is a Sony laser.
# will be on the laser and Mcm has it for I think $35
Posted on Apr 16, 2010
  • 1311 Answers
SOURCE: Replace spare tire hoist/lift assembly
The part number is 152477311
Posted on Oct 12, 2010
SOURCE: Trying to find replacement part
http://www.bettervac.com/bissell-016-4181-handle-assembly-for-big-green-machine.asp
Hopefully this helps.
Posted on Jul 16, 2011
How to assemble the trigger on a rainbow vacume
What is the part number of the trigger you purchased for replacement? Needed information so we can understand exactly what configuration you are working with.
RainVac
www.rainvac.com
Jul 13, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Bauholtz spare parts
why not just swap out the current engine for a factory new one or good quality used.
Jun 26, 2014 | Garden
Hitachi framing gun leaks air from trigger when pulled
use the lube that came with the kit, you can replace everything correctly but if oring gets pinched it will still leak
Aug 14, 2012 | Hitachi NR90AE Full Round Head Framing...
A Part broke off from my Yardman weedeater YM4570 the part that has two parts and are held by two springs which turns and expands when accelerates
The Yard-Man YM4570 is a nice 4-cycle gas trimmer.
It's hard to tell from your description, but the part you are referring to could possibly be related to the throttle assembly:
Throttle Housing & Trigger Assembly
Part Number: 753-04234
Throttle Trigger Spring
Part Number: 791-182690
You can get the part numbers and Operators Manual at MTD Products... click here:
Operators Manual
Nov 14, 2011 | Garden
All the sudden the nail gun stop working, pull the trigger air leaks out at trigger area
I had a similar problem with one of my nail guns. What I found was a small rubber o-ring in the trigger mechanism had split. Once I replaced this the problem was corrected and the unit functioned fine.
You could replace the whole trigger assembly for about $35. But if you remove the assemble and replace the split-ring this would only cost a couple of bucks at most.
Trigger assembly shown below. ereplacementparts.com is one possible source for the trigger assembly others can be found on the Internet.
Aug 21, 2011 | Dewalt Heavy - Duty 31° Clipped Head...
N62FN: air leaks at trigger switch how to replace o-ring.
Be careful, the leak may be within the trigger assembly itself. Check the link below for a pointer to a parts site that also has exploded diagrams of the gun. These diagrams will assist in parts replacement. The trigger assembly should be available for around $25.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Jan 02, 2011 | Stanley Bostitch N62fn Finish Nailer Parts...
Air coming out behind trigger.will sink nail
there is a split o ring on the trigger assembly that needs replaced or the whole trigger valve assembly needs replaced.
May 22, 2010 | Stanley Bostitch N86S 1 Factory...
My n59fn has huge air leak by the trigger and will not function
I had this problem once and the trigger was defective internally. You should be able to purchase a replacement trigger assembly at the link below.
Link: http://home-and-garden.become.com/tva6-trigger-valve-assembly--compare-prices--c205367842
Cost: $19.99
Hope this helps,
Dan
Apr 22, 2010 | Stanley Bostitch BT200K
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
