Question about Amco 60 Minute Kitchen Timer
How do you fix the ringer?
Broken ringer, piece fell off
Fix a halfway stuck tray on a ps2
There must be a broken piece of the tray thats blocking the process. Try to open the console using a screwdriver and get rid of the broken bits
May 22, 2015 | Sony PlayStation 2 (PS2) Console
How do I fix the broken release button for the handbrake?
Check with a Ford dealer regarding replacement. This is a safety issue and should be taken care of promptly.
Jul 16, 2014 | 2001 Ford Focus
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
Fuel injector replacement and broken piece fell in engine
That is His To EAT dont let him charge YOU for HIS Mistake. His Neglagence got him there. It Should be ILeagal
Look into it.
Jan 28, 2009 | 1987 Ford Tempo
Rectangle piece keeps falling out when I take lens off.
That's the Acute Matte Focusing Screen. They are made to be swappable and easily installed. While I don't know the specifics of your camera (I own a Maxxum 7000), I can assure you it's probably easily fixed, and probably not actually broken. Most likely, it's retainer just let go.
Jan 09, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Dell inspirion 5100 fell
Before you can think of fixing it, ask yourself what is there to fix.
open your laptop check for any broken parts on the board if its fine which i highly doubt also check whether any broken piece got into the fun. And for the monitor connect an external monitor and see what happens.
Jun 19, 2008 | Dell Inspiron 5100 Notebook
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Amco 60 Minute Kitchen Timer Logo
74 people viewed this question
Top Amco Home Experts
john h
Tom Chichester
Are you an Amco Home Expert? Answer questions, earn points and help others
